Author Topic: Autobox problem  (Read 3854 times)
Bojan
  • Croatia, Slavonski Brod
    • MV6 3.0
Re: Autobox problem
« Reply #15 on: 21 August 2008, 12:51:21 »
I've just got back from GM dealer, had a Tech2 plugged in, and it came out with a error code 16 - Magnetic cirrcut 2-3 - open loop (tech is on croatian, so this is my rough translation).
they have gave me this paper, which shows the part that is broken, according to the tech.
jimmas
  • stevenage, herts
Re: Autobox problem
« Reply #16 on: 21 August 2008, 15:42:26 »
that looks like it can be changed in situ, ie just drop the sumps and remove from side  of valve block, but not completly sure.
Re: Autobox problem
« Reply #17 on: 21 August 2008, 17:15:51 »
Has anyone looked for a thrust washer in the front sump yet?
sassanach
  • trowbridge
Re: Autobox problem
« Reply #18 on: 21 August 2008, 22:22:14 »
looks like you have this sussed!
Re: Autobox problem
« Reply #19 on: 21 August 2008, 22:43:44 »
Who? ::)
PM received by the way, I may try and call in this weekend or the one after and collect those boots!. If you want your cash beforehand let me know, I'll post/Paypal :y
sassanach
  • trowbridge
Re: Autobox problem
« Reply #20 on: 21 August 2008, 22:49:02 »
bojan by the look of it,a f@@ked 2-3 solenoid is'nt going to do any slushbox any favours ;D
Re: Autobox problem
« Reply #21 on: 21 August 2008, 22:51:02 »
My old 3.0 had a knackered soleniod - ended up changing the box ;D
Would the soleniod still account for the rough 1-2 change though, or is that still likely to be slop/thrust washer?
sassanach
  • trowbridge
Re: Autobox problem
« Reply #22 on: 21 August 2008, 22:58:59 »
fraid so 2-3 solenoid is on in first and second gear. no rush on the wedge bye the way ;D
Re: Autobox problem
« Reply #23 on: 21 August 2008, 23:03:38 »
I know but I'd like to get it settled :y
