Author Topic: hot air please  (Read 1580 times)
petejjf
  • nuneaton
hot air please
« on: 09 August 2008, 00:24:51 »
help????
i`ve had my car now for just over 1 year and love it.. its never let me down untill four weeks ago when the oil cooler went. which i replaced thanks to you nice people on here so thanks for that,, but have you ever gone through winter with no heat,, not nice ,,
i can get heat for a few seconds say about 20.. then it goes off and just cold air or warm not hot which we all need at some time..
any help at all would be great ,,,thanks pete,,, :(
FRE07962128
Re: hot air please
« Reply #1 on: 09 August 2008, 01:01:10 »
help????
With other cars this usually means an air lock within the cooling system causing the heater matrix to fail in providing heat, especially after working on your car.
With your miggy I would certainly open the water bottle cap when the engine is cold and then warm up the engine to operating temperature with the cap remaining off and carefully squeeze / manipulate the main water hoses and those to the heater matrix that enter the rear bulkhead on the lower left hand (drivers) side of the engine.  Be careful of hot water of course, but see if the water level suddenly goes down.  If it does, the air lock has been cleared.  Turn off engine, let cool for a few minutes then add a 50/50 mix of water and antifreeze up to the "max" mark and replace cap.   Your heater should then work fully again. :y
If this does not work your problem is something else and you need to come back and tell us. :(
« Last Edit: 09 August 2008, 01:05:53 by FRE07962128 »
Re: hot air please
« Reply #2 on: 09 August 2008, 09:46:37 »
When the oil cooler was replaced, was the cooling system thoroughly flushed out (about 20 times)?
petejjf
  • nuneaton
Re: hot air please
« Reply #3 on: 09 August 2008, 16:57:46 »
hi
 ive done it so many time`s ,,have forgot just how many,, i still get a bit of oil in the header tank.but it`s getting better, with each time, not new to working on car`s so can do most small job`s ok and will have a go at some other big one`s as well.. just new to this car but the heat has always been a problem untill the top hose came off the pipe which goes to the matrix in the bulk head after that it was ok untill now,,
Re: hot air please
« Reply #4 on: 09 August 2008, 19:14:13 »
Have you removed the hoses to baukhead, and flushed that through?
Forte do a coolant flush especially for the aftermath of oil cooler failure - may be worth a punt to get the last of the oil out?
mv6copcar
  • Essex, Halstead
Re: hot air please
« Reply #5 on: 09 August 2008, 19:15:45 »
help????
yes, do as above but have the heater blowers on at the same time, dash vents on full power. was told it does help.
petejjf
  • nuneaton
Re: hot air please
« Reply #6 on: 25 August 2008, 15:01:40 »
hi and thanks for all the help ..re- no hot air..
after some more flushing and more,, then more still didnt work..
so put the garden water hose into the bottum hose off the header tank.pulled off one of the matrix hose`s and ran it ,,,
and it`s all good so far ,,, cant wait for winter,,,lol
thankyou all for ideas,,pete :D
FRE07962128
Re: hot air please
« Reply #7 on: 25 August 2008, 16:53:46 »
That's good Pete, and especially as the problem was solved without spending money! ;)  Always a good thing with any car let alone a miggy! :y :y
Richard A
  • Aldridge, West Midlands
Re: hot air please
« Reply #8 on: 25 August 2008, 19:42:55 »
Don't forget - 50/50 antifreeze mix  :y
regards
richard a
richard a
Page created in 0.034 seconds with 20 queries.
