Author Topic: DONE PEDAL TEST FOUND CODES  (Read 1362 times)
skippybanger
  • bedford
« on: 25 August 2008, 20:10:38 »
hi i done a pedal test today as my management light come on and the results were 0300 and 0302 but i dont know the codes so can anyone help please
sophos9
  • Norfolk
Re: DONE PEDAL TEST FOUND CODES
« Reply #1 on: 25 August 2008, 20:16:12 »
Thats will be
0300 - random misfire
0302 - misfire on cylinder 2
Big_Roger
  • Southampton
« Reply #2 on: 25 August 2008, 20:17:46 »
Hi,
0300 is Random or multiple cylinder missfire detected.
0302 is Cylinder 2 missfire detected.
HTH
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
sophos9
  • Norfolk
« Reply #3 on: 25 August 2008, 20:20:09 »
Theres an echo in here  ;D
« Reply #4 on: 25 August 2008, 20:23:29 »
Worth checking for oil in the plug wells....
sophos9
  • Norfolk
« Reply #5 on: 25 August 2008, 20:32:04 »
Are you getting any misfiring and is it when you are on petrol or LPG?
skippybanger
  • bedford
« Reply #6 on: 25 August 2008, 20:42:40 »
there was a slight misfire now its bit worse its on both but worse on lpg only slightly worse though
« Reply #7 on: 25 August 2008, 20:43:41 »
Check that coil pack for oil in the wells and damage!
