Author Topic: Aircon Recharge?  (Read 5969 times)
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: Aircon Recharge?
« Reply #15 on: 25 August 2008, 22:49:08 »
Thanks for the tip however all these mobiles dont cover my area... (I'm in deliverance country  :y )
Trade club card holder
Code scanner available
lpgelite
  • Cumbria
« Reply #16 on: 25 August 2008, 23:36:19 »
Hmmmm,  tricky one this..
If your air con is just a bit tired but otherwise OK then there's very little Kwikfit can do to 'dangle berries' it up.
I had this decision to make with a Volvo. The a/c worked OK but not brilliant, so I deduced that it was not leaking due to the fact that there seemed to be sufficient gas to enable the compressor to run correctly.
I just felt it needed freshening up as there was no record of it ever having been vac'd out and recharged, as is considered good practice every three years or so.
Even the most simeon of fitters is able to hook up the machine, type in the vehicle details and leave it to do its own thing for an hour or so, which is as involved as it's necessary to get from their point of view.
You even get a print out of what's been recovered, how long and deep it's been held under vacuum and what new stuff has been put in.
The machine literally does it all on its own.
I wouldn't normally go to one of these places, but the Volvo's been fine ever since and I even blagged a deal on a couple of premium tyres while I was there. Got 'em fitted & balanced for same make / price as I could find mail order off t'internet or eBay...
They don't seem to try their tricks if you come across as a bit savvy, and not all their depots deserve the reputation the company's earned itself. Some are definitely and infinitely better than others.
Speaking as I found, I'd tread carefully but Carlisle was fine and I'd go there again if necessary.
Albert1
  • Herts
« Reply #17 on: 26 August 2008, 10:47:25 »
Recommend a company that sorted me out, mobile but has all the latest gear. www.aircondoctor.co.uk. I think it’s a franchise so there may be one in your area. They have a good Q&A section on the website that answers most common aircon questions.
Their FAQ section makes for hilarious reading: Q - How often should I run the air conditioning system in my car?  Their answer: "Ideally, all the time. It is false economy to turn the system off in the winter"
We've all heard that you should run the a/c at least every 2 weeks, even in winter, but all the time?  Pull the other one...
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
« Reply #18 on: 26 August 2008, 19:26:34 »
Aah you mean E.Anglia   ;D ;D ;D ;D
Omega 2.6 V6 Elite in Shiny Black
sophos9
  • Norfolk
« Reply #19 on: 26 August 2008, 19:42:34 »
Darn right.. *hick*
Had a ring around, spoke to Kwik fit and started to quiz them a bit, asked if they vacuum and how long it will take and they could not answer, they kept saying that they pressure test... erm case closed!
Spoke to another company that knew plenty but cost £88 then spoke to a specialist who charges £50 for a full service and adds UV, vacuums, tests etc before doing anything - will have a punt there!!
« Reply #20 on: 26 August 2008, 22:45:44 »
Yes there is  ;)
