Pages: 1 [2] 3  All   Go Down
Author Topic: well im stuck!!  (Read 4193 times)
Martin_1962
Re: well im stuck!!
« Reply #15 on: 26 August 2008, 13:38:25 »
Sound is difficult to locate - check the rear end as well
Omegatoy
  • UK
Re: well im stuck!!
« Reply #16 on: 26 August 2008, 21:28:38 »
took around 15miles to start making its noises today , and we ahem switched off the engine and coasted so we could hear it better funny enough the car without power steering assistance is not that heavy to steer!!both agreed it was definetly coming from the n/s front area,  so when it was safe to do so pulled over i leapt out and instead of pushing down on the ns for some reason i pulled it upwards, lo and behold the mrs said THATS IT!!  seeing the look of astonishment(or stupidity) on my face she said whats up ?unbelievingly i told her  from outside the car there is not a sound!!we swapped places aqnd she attempted to lift it a little bit :-/
you can only hear it when inside the car!!!
no wonder i havent been able to find it!! so the plan is as soon as i have a free day going to put it on the ramps with her inside the car whille I push on everything till she hears it!!! its almost cetainly steering or suspension related onwards and upwards! keep the suggestions coming guys!!! :y
    • 530D M Sport, 330i Coupe
Re: well im stuck!!
« Reply #17 on: 26 August 2008, 21:30:18 »
It's not a gold bullion bar in the glovebox is it?  ;D
Re: well im stuck!!
« Reply #18 on: 26 August 2008, 21:32:05 »
steering idler?
johnnycboy
  • Colchester
Re: well im stuck!!
« Reply #19 on: 26 August 2008, 21:33:15 »
steering idler?
my thoughts exactly
Omegatoy
  • UK
Re: well im stuck!!
« Reply #20 on: 26 August 2008, 21:50:11 »
knowing my luck it would be lead!!!
Omegatoy
  • UK
Re: well im stuck!!
« Reply #21 on: 26 August 2008, 21:53:44 »
steering idler?
I keep going back to check that cos its been niggling at me that it might be  but as said can find no free play in it and just in case shimmed it to tighten it after greasing it , and cannot find any movement in it , pin has no wear on it so im doubtful, but if i had a spare would change it just for me own peace of mind!! anyone fancy sending me one out??? :y
Re: well im stuck!!
« Reply #22 on: 26 August 2008, 22:03:48 »
steering idler?
May have a used one by friday but will have to see how useable it is (certainly doesn't make any noise but very slightly vague steering)
Omegatoy
  • UK
Re: well im stuck!!
« Reply #23 on: 26 August 2008, 22:25:14 »
steering idler?
slightly vague steering?would be interested just to see if it stops the noise regardless!! would then know for sure!! thanks bud let me know!!!
Omegatoy :y
Re: well im stuck!!
« Reply #24 on: 27 August 2008, 22:56:35 »
Steering box secure?
Re: well im stuck!!
« Reply #25 on: 27 August 2008, 23:29:14 »
Omegatoy, I have a brand new idler here in a box.
Where do I send it  :y
Omegatoy
  • UK
Re: well im stuck!!
« Reply #26 on: 28 August 2008, 11:03:36 »
yep thanks Mark, box has a minimum amount of freeplay when engine
off which disappears when engine is running
Omegatoy
  • UK
Re: well im stuck!!
« Reply #27 on: 28 August 2008, 11:04:13 »
pm awaiting your perusal :y
Re: well im stuck!!
« Reply #28 on: 28 August 2008, 11:13:47 »
Lol, when I say secure I mean as in bolted to the bulk head.
Omegatoy
  • UK
Re: well im stuck!!
« Reply #29 on: 28 August 2008, 20:07:48 »
LOL first word was "yes"! meaning it is well secure all bolts checked, then the other bits were just to let you know had checked ev erything connected to it, shouldnt have added thanks a suppose but i was actually thanking you for the idea :y
Pages: 1 [2] 3  All   Go Up
Page created in 0.04 seconds with 16 queries.
