Author Topic: Autobox...slow changing into gear from stationary  (Read 3069 times)
MutantCav
  • Gainsborough
Re: Autobox...slow changing into gear from stationary
« Reply #15 on: 29 August 2008, 15:14:37 »
Yeah the car is now basically instantaneous as it should be...prior to the top up it was probably about a second or two, felt like it was stuck in neutral awaiting change and car rolled back while it was waiting to go into gear so quite dangerous too...but hadnt been driven like that, was ok before the fluid leaked out the pipes so no damage to the box I'm sure...
Not sure I would agree with the ABS diagnosis...should be immediate even if you leave it I would say...but check the level if its not and see...
