Author Topic: Lambda sensor low voltage -car broken down -help!  (Read 3648 times)
Re: Lambda sensor low voltage -car broken down -help!
« Reply #15 on: 07 September 2008, 23:42:34 »
Before you condemn it (or do too much work) try a little old trick ... stick a desertspoonfull (about 10 cc) of lightish oil - redex used to be great for this - in the suspect pots and leave overnight, then do the compression test again. If it improves drastically you may have a sticky piston ring or two, in which case repeating the exercise 4-5 times may well free them up and restore full compression.
HTH
Agree with what you say but, if my engine was at that stage, I wouldn't be relying on it   :'(
Matchless
  • Nottingham
    • A white van
« Reply #16 on: 07 September 2008, 23:47:59 »
Why was the head gasket changed previously? Could it have had a belt or tensioner failure in the past?
Page created in 0.008 seconds with 16 queries.
