Author Topic: 1 for TB & Mark  (Read 4093 times)
justme
  • Shadowland
  • Testing by TB
1 for TB & Mark
« on: 07 September 2008, 17:06:45 »
what centronics cable & connector is req for 95 3l Elite.
where to get it from
Test sig...
Re: 1 for TB & Mark
« Reply #1 on: 07 September 2008, 18:15:11 »
Eh? Can't think of anything on an omega that uses a centronics type connector?
philhoward
  • Staffs
  • Love the engines, so put one in something else..
Re: 1 for TB & Mark
« Reply #2 on: 07 September 2008, 20:16:19 »
Last thing I saw with a Centronics connector is the head HP4 laserjet printer under my desk...you sure you mean Centronics??
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
Re: 1 for TB & Mark
« Reply #3 on: 07 September 2008, 20:49:26 »
Must be on about the socket from the paperclip test, looks similar to one.
Re: 1 for TB & Mark
« Reply #4 on: 07 September 2008, 20:52:58 »
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
Just been and had a look, shows how bad my memory is, socket is nothing like one, but I still think this is probably what he means.
philhoward
  • Staffs
Re: 1 for TB & Mark
« Reply #5 on: 07 September 2008, 21:02:09 »
Oh...the J1962!!
Sorry - place i used to work at made their own J1962 leads for their EOL test kit for LandRover, Jaguar and Aston Martin ...
justme
  • Shadowland
  • Testing by TB
Re: 1 for TB & Mark
« Reply #6 on: 07 September 2008, 22:04:45 »
Thats another opp's
That will be a Serial cable then
Test sig...
philhoward
  • Staffs
Re: 1 for TB & Mark
« Reply #7 on: 07 September 2008, 22:08:52 »
So...do you mean the diagnostics cable?
justme
  • Shadowland
  • Testing by TB
Re: 1 for TB & Mark
« Reply #8 on: 07 September 2008, 22:21:01 »
Yep
Test sig...
Re: 1 for TB & Mark
« Reply #9 on: 08 September 2008, 00:02:49 »
Ebay?
Re: 1 for TB & Mark
« Reply #10 on: 08 September 2008, 12:03:54 »
Yep
Sorry, you need to say what you are after, and what you are trying to achieve.
If you are after full dealer level diags, then £2750 will buy you the equipment, then you need a subscription to webTIS
If you are after cheap and nasty diag system, cheapo tech2, but MUST have proper serial port on laptop. Approx £25
There are a couple of options in between.
justme
  • Shadowland
  • Testing by TB
Re: 1 for TB & Mark
« Reply #11 on: 08 September 2008, 21:10:35 »
Yep
Hi TB,
     Got centronics on the brain at present.
              Certainly not dealer levell, or cheapo.
 just need a cable & plug/plugs to connect a laptop with a serial port
for engine & gearbox ecu (or are they the same?)  Just experimental ?
at present
Test sig...
Re: 1 for TB & Mark
« Reply #12 on: 08 September 2008, 21:20:20 »
Yep
Hi TB,
at present
Still not sure what you are after  :-/
Are you trying to make your own diags tester?
If not, what software are you planning on running?
justme
  • Shadowland
  • Testing by TB
Re: 1 for TB & Mark
« Reply #13 on: 08 September 2008, 21:55:01 »
Yep
Hi TB,
at present
Hi TB
             Sorry about that.  Only needed a quikie. Start again.
got a laptop hanging around only used for GPS.
want to make up a cable to connect to Engine/Gearbox ecu.
That is it for the mo.
So what plugs req
Software now that's another story SH.
Test sig...
philhoward
  • Staffs
Re: 1 for TB & Mark
« Reply #14 on: 08 September 2008, 22:08:50 »
For the plug..ebay 220277615672..
Page created in 0.025 seconds with 20 queries.
