Author Topic: ECU faulty?  (Read 2902 times)
Re: ECU faulty?
« Reply #15 on: 12 September 2008, 22:06:19 »
lol, sounds more like wiring or the connector.......remember that when moving an ECU its not like your actually straining the electronics!
Any idea which wire in specific I should look for Mark? Maybe an ICV one or something? :D
I removed the ECU earlier in order to inspect for dodgey wiring, when looking at my Lambda issue, for all you curious people :y
justme
  • Shadowland
  • Testing by TB
Re: ECU faulty?
« Reply #16 on: 12 September 2008, 22:39:27 »
Think your trying to compete with Tim.
Test sig...
iainb
  • West Midlands
Re: ECU faulty?
« Reply #17 on: 12 September 2008, 22:53:38 »
Sorry I didnt explain my self better. The wires are dressed which means they are of different lengths so when you wagle the ECU  about you are stressing the shorter wires and this can lead to a breakdown in comunication,hence the car may see a fault and go into limp mode.So as I said if it work leave it alone
Cheers
Re: ECU faulty?
« Reply #18 on: 12 September 2008, 23:08:33 »
which one , LPG ?
Nope the main petrol ECU.
There is no LPG on this car :y
Yet ::) ::) :-? :-? ;) ;)
Re: ECU faulty?
« Reply #19 on: 13 September 2008, 00:07:38 »
Cheers
The point is, it doesn't work. ;)
If something is getting disturbed it indicates an intermittent connection and this might be related to the Lambda sensor fault.
Might be worth unplugging the ECU and checking the connector is clean. Also check any other connectors between ECU and Lambdas. (IIRC) there's another multiway connector between engine and body looms.
Taking the engine loom out of the cable trays and inspecting for damage might be worthwhile.
Difficult to say what caused the fast idle. IACV may have been opened by a duff connection but could equally be that the ECU saw and intermittent signal and opened the IACV to prevent a stall.
A peek at the live data while waggling things might show something.  :-/
Page created in 0.014 seconds with 18 queries.
