Author Topic: Crank Sensor  (Read 2870 times)
Re: Crank Sensor
« Reply #15 on: 17 September 2008, 10:15:22 »
Hi Mark,
Just got my car back from the garage. Im scratching my head with this one as is the mechanic. As you know the car wouldnt start and suspected the crank sensor altho today the mechanic took off the panel by the drivers side well and said that he "played around" with the wires down there and it started pissing out fuel from the injectors. He put them back on and lo and behold it started. He suspects a bad earth but im not going to be charged 40 quid an hour for him to test every wire. Do you have any suggestions? I have to drive to Bristol on Friday so im a little wary.
Regards,
James
Think hes throwing a smoke screen
There are no wires in the drivers side panel which are involved with the ECU as its all under the bonnet.!
Now you have the car back, can you read the fault codes as per the above post?
jamescropley
  • Grantham, Lincs
Re: Crank Sensor
« Reply #16 on: 17 September 2008, 10:21:43 »
Im going to have a go in a bit. If i cant read anything (it looks a bit puzzling counting all the flashes) when is the earliest you are available to read the codes? Oh yeh how much do you charge?
Re: Crank Sensor
« Reply #17 on: 17 September 2008, 10:38:33 »
James you are lucky , you can call Marks DTM ..
I'm not that lucky :-/
