Author Topic: Self Levelling ECU  (Read 998 times)
Self Levelling ECU
« on: 19 September 2008, 20:54:08 »
Where is it, or is it integrated into level sensor....
Re: Self Levelling ECU
« Reply #1 on: 19 September 2008, 20:59:27 »
Sensor appears to drive the compessor via a relay, and a solenoid valve directly.
There's a diagnostic pin connected directly to the sensor too.
« Reply #2 on: 19 September 2008, 21:03:28 »
Its built into the sensor.....couple of feeds, diag wire and two outputs....one feeds a relay to drive the compressor and the other a valve to vent air
« Reply #3 on: 19 September 2008, 21:18:30 »
Car not responsing well to heavy loads, and never hear compressor of late.  Attempts to do diags result in Tech2 permentently Waiting For Connection.
Fubar ECU?
« Reply #4 on: 19 September 2008, 21:20:46 »
Fubar ECU?
Ah 'dangle berries', pin 8 of diags plug, same as GID...  ...the plot thickens...
« Reply #5 on: 19 September 2008, 21:34:44 »
Fubar ECU?
 :-X :-X :-X :-X  ::)
« Reply #6 on: 19 September 2008, 21:44:56 »
Fubar ECU?
 :-X :-X :-X :-X  ::)
You cruising for a bruising, laddie?
;D
