Author Topic: soft brakes.  (Read 3085 times)
Re: soft brakes.
« Reply #15 on: 19 September 2008, 23:23:31 »
hygroscopic which means that it attracts water.....
You would be f***ed if your fluid had a fear of open spaces!
yeah yeah... changed it now!    ;D   :y
Ah ..... but not before I highlighted your deliberate mistake!  ;D
 ;D    :y
Why am I not surprised!  :P
manny
  • bromorough.Wirral.
Re: soft brakes.
« Reply #16 on: 19 September 2008, 23:26:00 »
Is there a photo of the brake bleed nipple on this forum?Can you get to it with the wheel on?
2001 OMEGA MV6
Re: soft brakes.
« Reply #17 on: 19 September 2008, 23:30:26 »
Photo? Doubt it. ;) The front wheel's bleed nipple is probably accessable if you put full lock on, but for the amount of time it takes to jack up the car & remove the wheel ........ besides it'll give you more room to see what you're doing, especially if you're going to clamp the flexi brake hoses. :y
manny
Re: soft brakes.
« Reply #18 on: 19 September 2008, 23:34:37 »
How much brake fluid do you need to renew the old stuff?
2001 OMEGA MV6
hotel21
  • The Kingdom of Fife
Re: soft brakes.
« Reply #19 on: 19 September 2008, 23:39:29 »
I normally buy a nice fresh litre and know that I'm going to have quite a bit left over for top ups if required....
There again, I try to have a wee bit more than actually needed, rather than a bit less than reallt reallt required to finish the job on a sunday afternoon, if you follow...   ;)
Re: soft brakes.
« Reply #20 on: 19 September 2008, 23:49:51 »
Brake fluid is very cheap from a dealers on TC too, as I found out the other day. :y
jb
  • bucks
    • 3.2 Elite
Re: soft brakes.
« Reply #21 on: 22 September 2008, 10:40:31 »
likely cause of soft brakes long pedal on the omega is often rear pads siezed in caliper and or siezed caliper piston.............
Page created in 0.009 seconds with 17 queries.
