Author Topic: Camber adjustment - how?  (Read 6226 times)
Kaycee
  • Doncaster
Re: Camber adjustment - how?
« Reply #15 on: 19 September 2008, 20:53:31 »
yes thats very true thats why its best to get camber correct then go and get toe done ive not found an easy way to do toe mind in measurement terms i have mine set 10mm nearside 9mm ofside and tyres showing not the slightest wear also same on my previous 2.5 cdx that had 2 sets of wishbones in the 7 yr i had it but that was one great car hope this one is as good
There is a tide in the affairs of man if taken at the flood will lead on to greater things
The Barge Captain
« Reply #16 on: 24 September 2008, 18:57:18 »
Well...
Having expected trouble undoing the knukle to strut bolts, they came off very easily.
Adjusted using a spirit level, plates under the tyres to get the car level and a bit of rusty triganomitry.
Checked the torque figure and tightened....
Too not much before the bolts went "soft"
Now i know Mr Haynes says to use new bolts, so 2 new bolts fitted and torqued up ok.
I think someone had buggered around with this in the past, and due to not being tightened correctly the camber had collapsed in on it's self  >:(
