Author Topic: Oil Change.  (Read 1379 times)
Brewster
  • North Lincs
Oil Change.
« on: 02 November 2007, 16:38:21 »
I've just changed the oil on my MV6, which turned into a pig of a job, so I thought I'd do a little write up.
The Best way to change your oil.
1 Drive down to your local specialist when the mileometer reaches 3000 miles since the last oil change.
2 Drink a cup of complimentary tea.
3 15 minutes later, pay mechanic £50 or so and leave with a properly maintained vehicle.
Total 15 minutes. £50.
The 'Real' way you change your oil.
1 Go to local motorfactors and pay £30 for 5 litres of Oil, Oil Filter and hand cleaner.
2 Search around the garage for your axle stands.
3 Jack up car and place axle stands. Lower car, realise that the floor pan is now getting bent as the stand is in the wrong place. Re-jack the car and place the stand again. Finally lower car.
5 Get underneath car and try to loosen sump plug with a Torx wrench that's about the right size.
6 Round out sump nut with torx wrench, so try again with the correct torx bit you found at the bottom of the tool box.
7 Still not having much luck with the nut, so try a pair of Molegrips on the nut. But they keep slipping off.
8 Try swearing at it. That often helps.
9 Finally manage to loosen the nut using a hammer and chisel.
10 Now that the car is dripping oil, you realise you've not got a suitable oil tray. The bucket you were going to use won't clear the sump.
11 Run around the house like a mad man trying to find something to use.
Note: Don't be tempted to use that fruit bowl the mother in law bought for your anniversary present. It's not worth the hassle.
12 Find a large plastic bottle and cut the top off with a kitchen knife. Cut yourself with the knife whilst you are at it.
13 Run back out to the car and place the oil tub.
14 Get under the car and remove the sump nut. Loose the nut in the oil tub.
15 Again, swearing here often helps.
16 Once the oil has finished dripping, remove the tub and fish out the nut. You now have a very oily hand.
17 Drip oil over the road, through the house and all over the sink after you realise you've not brought a rag out with you.
18 Get back under car and realise you need the oil filter strap.
19 You can't be bothered to look for it, so try with all your might to remove it with your bare hands.
20 Get out from under the car and look for the oil filter strap.
21 Can't find the oil filter strap, so go back out to the car and take a large flat headed screwdriver and a hammer.
22 Get back under the car and hammer the screwdriver through the oil filter.
23 Get oil down your arm and drips over your head and face.
24 Rush back into the house to the sink, again realising you didn't bring a cloth out with you.
25 Swear.
26 Back out to the car. Smear a ring of new oil over the oil filter gasket and fit new oil filter to car.
27 Put the required amount of oil into the engine via the rocker cover oil cap.
28 Notice oil all over the drive and realise you didn't refit the sump plug nut.
29 Search around trying to find the nut.
30 Remember it's back in the house next to the sink.
31 Run back into the house, grab the nut run back out to the car.
31 Get underneath the car. Get oil all over your shirt as you are lying in a pool of oil.
32 Refit the nut and finger tighten.
33 Swear as you realise just how much oil is over the drive as well as over you and your shirt.
34 Go back into the house. Shower and change into the overalls you should have put on before you started.
35 Get a bag of kitty litter and a piece of old carpet from the garage.
36 Put kitty litter on the oil slick that looks like something from the Exxon Valdies.
37 Put carpet onto of kitty litter/oil slick sludge.
38 Realise that the 'old' carpet was a piece you were saving to re-do the top stair with.
39 Swear.
40 Tighten nut with torx bit.
41 Slip with wrench and bang knuckles on engine or inner wing.
42 Bang head on sump or inner wing in reaction to step 41.
43 Begin swearing fit.
44 Throw torx wrench.
45 Realise that it has gone somewhere not so easily accessible. E.g. Under a large bush, a car etc.
46 Spend five minutes swearing and fishing the wrench from the inaccessible place.
47 Tighten nut.
48 Refill remainder of oil only to realise that you've now not got enough.
49 Go back to local motorfactors and pay £29 for 5 litres of Oil, 5 litres of industrial Oil cleaner and a new oil filter strap.
50 Tighten the oil filter with the new oil filter strap.
51 Jack up the car and remove the axle stands. Lower the car.
52 Move the car back and get the power washer out.
53 Put the industrial oil cleaner onto the oil slick and spray away.
54 Realise you are getting oil splats all over the car so start to wash that too.
55 Get an earful from the wife as she complains that you've been at that for hours and you are now washing the car.
56 Finish washing the car and the drive.
57 Put all your tools away. Placing the new oil filter next to the old one you had but couldn't find earlier.
58 Swear.
59 Go in the house and ask what is for tea.
60 Wonder why you've just been slapped.
Total £30 for 5 litres of Oil, Oil Filter and hand cleaner.
£150 to have the Hall, Living Room and Dinning room carpets professionally cleaned to remove the oil.
£12 to replace the shirt that was ruined by oil.
£2 to replace the bag of Kitty litter used on the oil slick.
£1 for the box of plasters.
£29 for 5 more litres of Oil, 5 litres of industrial Oil cleaner and another oil filter strap.
£150 to have the dent in the floor pan repaired so that the car passes its next MOT.
3 hours 40 minutes. Total: £364
Re: Oil Change.
« Reply #1 on: 02 November 2007, 16:41:41 »
oil change on the 4 pots is a peice of pi$$
Jack car up 1 foot.
slide tray under car, remove sump plug, let oil drain, reach down into engine bay, twist and release filter. Let it drain. Release oil filler cap.
Clean.
Re-assemble.
Done.
Cost under £10!
Re: Oil Change.
« Reply #2 on: 02 November 2007, 16:46:12 »
It's a 20 minute job on any car once you've done it once  :y
miggy
Re: Oil Change.
« Reply #3 on: 02 November 2007, 17:36:54 »
Brilliant, that would look good as a sketch on the carry on films.
LMAO
 ;D ;D ;D ;D ;D ;D
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Oil Change.
« Reply #4 on: 02 November 2007, 18:25:10 »
Like it :y
 ;D ;D ;D ;D
I like red cars
omegaman2
  • Kilsyth, Glasgow G65
  • cruise , tints, shinbuster,advanced drinking test
Re: Oil Change.
« Reply #5 on: 02 November 2007, 19:34:23 »
yep been there before ;D
dieseldonicely
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Oil Change.
« Reply #6 on: 02 November 2007, 19:39:16 »
Jack car up 1 foot.
Clean.
Re-assemble.
Done.
Cost under £10!
Nice read by the original poster but i agree with Tunnies Method  :y
« Last Edit: 02 November 2007, 19:39:48 by Markiec »
bertiecbx550
Re: Oil Change.
« Reply #7 on: 02 November 2007, 20:03:52 »
HA HA HA HA I just peed me self reading that..i did my own oil an filter change last week even renewed the sump plug  :o didn`t swear once ::)
Taxi_Driver
Re: Oil Change.
« Reply #8 on: 02 November 2007, 20:42:02 »
Thats the sorta thing that would happen to me  ;D ;D
Plus getting my legs run over by passing car (on road parking!)  ;D ;D
Less than a tenner for the oil and filter and twenty notes for my local garage to change it.....plus i dont have to get rid of the old oil .... bargain  :y :y
Tony H
  • liverpool
  • Black Elites are luurvley
Re: Oil Change.
« Reply #9 on: 02 November 2007, 20:55:49 »
Briliant ;D ;D ;D
