Author Topic: Having A Replacement Key Cut Problem.  (Read 3097 times)
Pete Elite
  • Uxbridge, Middlesex
Re: Having A Replacement Key Cut Problem.
« Reply #15 on: 04 October 2008, 16:09:27 »
Thanks lads,
                 As i said i bought the non-transponder blank key from the Forum shop so no problem with the key :).
   Jamie which one is the one without the little dome on the sunroof motor cover?
                      Cheers,
                                Pete :y.
Without dome is RF, so key needs transponder.  Transponder needs programming to car, and this requires a Carpass (and a tech2!)
   Hi Jamie,
               I think i've got this Transponder/Non-Transponder key thing all wrong. You say that no dome is RF and so needs Transponder and Programming, well mine is RF then which means i should have a Transponder type key :-?.
  What does the chip look like when you open the key, if it's a small rectangular bit in the lower left space in the key looking at it with the blade to the left then it looks like i've got a Transponder key in which case i purchased the wrong key from the Forum shop :'(.
