Author Topic: Wheels locked up, like brake was on  (Read 998 times)
Omegadoha, Desert Member
  • Doha, Qatar
« on: 04 October 2008, 12:35:21 »
Further to the crankshaft sensor failure back in June, I experienced another failure today, this time with the wheels and had to call out the recovery service again in 38 dec celcuis heat.
I was driving along at about 60 kmph and suddenly there was strange sensation like the brakes were engaging. I had to brake anyway and then just couldn't move the car. The gears were engaging but if felt like the handbrake was on only stronger. With D selected I could only edge the car forwards slightly. Even in neutral it wouldn't move as I might have expected it to given I was on a incline. What can make the wheels lock up like that? :o No warning lights nothing.
Anyway the wife and daughter came to the rescue like the Powerpuff girls in the Honda CR-V.  ;D and we watched the Omega being loaded on the back of the resuce truck and off to Mannai for repairs.
Re: Wheels locked up, like brake was on
« Reply #1 on: 04 October 2008, 13:34:19 »
had similar on my old omega. the hand brake shoe lining had fallen off and jammed the hub. lets hope its that :-/
markey mark
  • SLady bitshorpe north lincs
« Reply #2 on: 04 October 2008, 16:23:22 »
either that or gearbox has locked up !  :-/
« Reply #3 on: 04 October 2008, 16:30:39 »
Have known failed master cylinder seals lock brakes on.  Try cracking bleed valves on calipers open a touch - if brake fluid spurts out under pressure thats yer problem.
