Author Topic: heatin fan staying on max  (Read 1393 times)
Spiceboy1
« on: 04 October 2008, 17:46:40 »
i have just got a Omega v6 and have a couple of things that need sorting out, the first is the heating fan has just decided to stick on even with the ignition off, i am having to remove the fuse, also the drivers seat electics dont work, when the buttons are pushed it just clicks! can anybody help?
markey mark
  • SLady bitshorpe north lincs
Re: heatin fan staying on max
« Reply #1 on: 04 October 2008, 17:47:58 »
has it got climate control fella ?? :-/
Spiceboy1
« Reply #2 on: 04 October 2008, 18:01:37 »
yes it has..
markey mark
« Reply #3 on: 04 October 2008, 18:13:21 »
could be the fan speed controller under dash at passenger side ! have a good spare here if you need one ! :y
Spiceboy1
« Reply #4 on: 04 October 2008, 18:17:35 »
is there a way i can test it? what does it look like so i can locate it, does it come out easily? sorry-questions questions questions!
markey mark
« Reply #5 on: 04 October 2008, 18:22:28 »
dont think so ! get your head in passengers footwell and its to right of main fan ! sometimes ! no worries  :y
« Reply #6 on: 04 October 2008, 18:22:32 »
And its normaly destroyed by water getting in the duct from a blocked scuttle drain under the bonnet so clean that out to!
Spiceboy1
« Reply #7 on: 04 October 2008, 18:25:02 »
as soon as it is light tomorrow-i will check it out! how much for a replacement posted to Buckinghamshire if needed? also any tips on why drivers seat electics dont work and just click when buttons are pushed?
markey mark
« Reply #8 on: 04 October 2008, 18:25:59 »
will do one for £15 posted matey !  :y usally a pound coin jammed in runner  ;D
« Last Edit: 04 October 2008, 18:26:39 by markey_mark »
Spiceboy1
« Reply #9 on: 04 October 2008, 18:28:36 »
i'll check for the £1 coin lol, it doesnt recline go up-down etc - i assume its the contorl box under the seat or a relay or something!
markey mark
« Reply #10 on: 04 October 2008, 18:29:28 »
as you sit there try bouncing in seat as you move it !  :D
Spiceboy1
« Reply #11 on: 04 October 2008, 18:31:51 »
what will that prove? lol apart from prove that i look stupid! lol
« Reply #12 on: 04 October 2008, 19:03:50 »
Sometimes the seat sieze up due to lack of use (most people set and forget)...bouncing often frees the motors off again
