Author Topic: Disconnecting throttle cable  (Read 1362 times)
eddie
  • Cardiff
« on: 04 October 2008, 18:58:17 »
Hi all, I am currently in the middle of removing intake plenum to clean all the intake breathers,throttle body etc, and more pertinent, replace the coil pack.
Unfortunately I have reached a show stopper in that I cant for the life of me get the throttle cable connector to throttle arm off.
I have removed the ? shaped clip but the damn cup still doesnt come off the small ball joint--I've used plenty of force both with a small screwdriver behind the cup and with a pair of pointed pliers,no go!
Anyone have any tips or suggestions to get this bu**er of?
I did think of leaving the body in situ and just flipping the plenum over and out of the way but it would mean I would not be able to remove the breather assembly for cleaning.
eddie
Re: Disconnecting throttle cable
« Reply #1 on: 04 October 2008, 18:59:59 »
Remove the plenum with the cable attached, and then unbolt the throttle body with 4 bolts at at front :y
Where in Cardiff are you?
eddie
  • Cardiff
« Reply #2 on: 04 October 2008, 19:57:06 »
Thanks james,that would solve the removal of breather assembly.
Just have to clean the throttle body in situ.
Too dark now continue tomorrow!
Fairwater.
eddie
Phil B
  • South Wales
« Reply #3 on: 05 October 2008, 17:57:12 »
It does come off mate honestly, it just needs some persuasion from the right angle!
