Author Topic: Water in passenger footwell!!  (Read 2647 times)
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Re: Water in passenger footwell!!
« Reply #15 on: 08 October 2008, 16:13:23 »
Everytime I lift the bonnet first thing I check is the scuttle drains, I had the passenger side blocked 18 months ago.
I advise anyone who has had this problem to regularly check especially if you park near trees or hedges like me. The amount of crap that gets down there needs to be cleared.
It's best to remove all of foam sound insulating material under the carpets front and back to get it properly dry. I had to cut mine out to get it properly dry, it does take a while to dry cause it's like a big sponge holding water. Some have used a wet n dry vac to suck it out, it needs to be dried out properly or it will start to stink like a bad drain.
Mick
I agree with you ..... its the first thing i do now when the bonnets popped ... make sure its clear and dry  :y
