Author Topic: Dead Battery  (Read 3565 times)
Bandit127
Re: Dead Battery
« Reply #15 on: 14 October 2008, 17:42:32 »
Hi, I'm new and having same problem but can get in boot but can't get back seats down. How can I do it from the boot?[/quote
Its almost impossible without forcing the seats foward. unless someone else knows otherwise!!!!
Pop the boot light out and 'jump' across the red & brown wires!  :y It works ... cos I've done it! Far easier than crawling under front wing, but obviously only applies to PRE face lift cars.
Just in case - please do not try to 'jump start' using the above advice. 10 or 15 minutes should give the dead battery enough juice to unlock and start the car.
Obvious to most - but maybe not all...
Re: Dead Battery
« Reply #16 on: 14 October 2008, 17:48:16 »
I did try to say jump across rather than jump start  ;) I used A N Other battery to just supply the car while I used the key in to lock to open the car.
You're never going to able to start the car via the boot light wires though, no matter hw long you leave the car conected to them. :y
Bandit127
Re: Dead Battery
« Reply #17 on: 14 October 2008, 18:13:47 »
Andy - you COULD connect a battery charger using your method. As long as the original battery is OK you could get fully charged in 8-12 hours.
More than once I have used old, knackered jump leads that wont carry starter current any more to charge a dead battery with enough for starting in about 10 minutes (off the alternator).
« Last Edit: 14 October 2008, 18:14:51 by Bandit127 »
Re: Dead Battery
« Reply #18 on: 14 October 2008, 18:23:33 »
Yes you could!  :y
Can I change my mind& agree? ::)  :y  :y
Ilija
Re: Dead Battery
« Reply #19 on: 17 October 2008, 23:13:42 »
If you deadlocked it then it will be a bugger to budge...
or get under the engine bay and connect jump leads to the positive of the starter motor and the negative to the body...
Had the same problem with my '95 V6. Deadlocked and dead battery. Solved it by opening the boot and taking out the boot light (located center, top when boot is closed) and connecting fresh battery to light terminals (Double-check polarity!) for 10-15sec.
Opened quite nicely then :)
« Last Edit: 17 October 2008, 23:16:36 by Ilija »
Re: Dead Battery
« Reply #20 on: 17 October 2008, 23:16:13 »
Had the same problem with my '95 V6. Deadlocked and dead battery. Solved it by opening the boot and taking out the boot light (located center, top when boot is closed) and connecting fresh battery to light terminals for 10-15sec. Opened quite nicely then :)
suggested that one already!  ;D
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: Dead Battery
« Reply #21 on: 17 October 2008, 23:18:46 »
lol i'v had this problem and just tried locking and trying to unlock a couple of times to get a bit of a swing on my hand lmao! it's stiff when you deadlock it but does budge without the key snapping or anything
V8!!!!
Ilija
Re: Dead Battery
« Reply #22 on: 17 October 2008, 23:19:09 »
Andy B: Sorry :) must have missed it when I ran through the thread
lol it's stiff when you deadlock it but does budge without the key snapping or anything
Tried it but I stopped when I felt the key is going to snap  ::)
« Last Edit: 17 October 2008, 23:25:08 by Ilija »
JasonH
Re: Dead Battery
« Reply #23 on: 18 October 2008, 10:27:10 »
You mentioned caravan stuff. If you have a towbar with a 12S socket there's a fused permanent 12V feed there (pin 4). Connect 12V to it, give it a while to put some juice back in the battery and you should be in business.
