Author Topic: ignition barrel  (Read 2944 times)
hp7166
  • Bridgend
Re: ignition barrel
« Reply #15 on: 17 October 2008, 19:18:55 »
will take a picture in the moring of the whole thing and take it from there
Cheers
Rob
Re: ignition barrel
« Reply #16 on: 17 October 2008, 19:27:58 »
Cheers
Rob
OK!  :y
hp7166
  • Bridgend
Re: ignition barrel
« Reply #17 on: 18 October 2008, 11:14:36 »
ok got the pic
Hope you can help
Cheers
Rob
Re: ignition barrel
« Reply #18 on: 18 October 2008, 14:21:28 »
ok got the pic
Hope you can help
Cheers
Rob
tha's gorra bit missin'  ::) Here's mine  :y
Wiper switch moved out of the way
hp7166
  • Bridgend
Re: ignition barrel
« Reply #19 on: 18 October 2008, 18:04:40 »
looks expensive will need to go to a scrappy and see what i can find
thanks for you help andy
Re: ignition barrel
« Reply #20 on: 18 October 2008, 19:11:40 »
It might be easier to fit a complete column. Is yours fixed ie your wheel doesn't tip? I'm sure that you could swap tp the later type.  :y
hp7166
  • Bridgend
Re: ignition barrel
« Reply #21 on: 18 October 2008, 19:19:14 »
It dosnt tip at the mo will have to keep a eye out for a colum from somewhere
thanks for your help
