Author Topic: Oil leak update  (Read 2684 times)
Re: Oil leak update
« Reply #15 on: 22 October 2008, 22:53:41 »
Anyone else who wishes to their 10p's worth .. the original photo's/description can be found here .. at the time I thought it was ATF .. now known to be Engine oil ..  :)
http://www.omegaowners.com/forum/YaBB.pl?num=1223978808
Re: Oil leak update
« Reply #16 on: 22 October 2008, 22:54:53 »
I have EXACTLY the same leak mate  >:(
Matchless
  • Nottingham
    • A white van
Re: Oil leak update
« Reply #17 on: 22 October 2008, 23:05:23 »
Well, if it was the crank seal then the back of teh flex plate would be pretty caked in it.
The red 2.0 I had managed to leak from the crank seal without any sign of oil on the flywheel.
Matchless
  • Nottingham
    • A white van
Re: Oil leak update
« Reply #18 on: 22 October 2008, 23:18:34 »
I would clean all around the block with Gunk or strong traffic film remover, especially the block - sump joint. Get it really clean then blast with a pressure washer or hose. It should then be really clean and dry so any oil running down from above should leave a 'track'
Have to say that it does sound like the crank seal though.
If you change the seal you need to make up a sleeve to help fit the seal without damaging the seal lips.
I had access to some .006" brass shim stock but coke or beer tin should be ok....just cut a strip with scissors and form into a tube which fits tightly onto the crank. Wrap with selotape to avoid any sharp edges.
Carefully slide the greased-up sleeve into the seal then fit the sleeve to the crank. You can now tap the seal home without any risk of the seal lips inverting.
« Last Edit: 22 October 2008, 23:19:51 by Pete »
