Pages: 1 [2] 3  All   Go Down
Author Topic: 2.5TD Tractor poor economy  (Read 5487 times)
osealy
  • dublin
Re: 2.5TD Tractor poor economy
« Reply #15 on: 29 October 2008, 14:26:21 »
My previous TD had leaky ijector 4. Visible fuel around injector. Whiff of diesel in hot weather/slow traffic. But if it was parked up in rain huge rainbows on ground. Mid used to read 57mpg when it did 34ish same as my other two. I think 41mpg is over optomistic for an auto.
« Reply #16 on: 29 October 2008, 14:44:11 »
Hows the oil?
« Reply #17 on: 29 October 2008, 19:23:11 »
Hows the oil?
Certainly not 3g overfilled ;D
Seriously, was considering similar, but that would then leave a massive oil slick somewhere.
Oil level very stable in betweeen 3k changes.
If I have misread your diags, then oil seems OK, goes black instantly after change, changed every 3k.  A small bit of oil weeps from egr (later egrs have an oil drain - I've currently got an earlier type egr on)...
iainb
  • West Midlands
« Reply #18 on: 29 October 2008, 19:33:11 »
High pressure fuel lines all tight ?
« Reply #19 on: 29 October 2008, 19:36:44 »
They are now that Omegatoy and I have replaced one of the pipes.
iainb
  • West Midlands
« Reply #20 on: 29 October 2008, 20:07:41 »
Maybe worth another look at the high pressure lines as they may have backed off.
On my old Courier van I put a couple of turn of PTFE tape on the threads as the fixings were worn and kept backin off.
Omegatoy
  • UK
« Reply #21 on: 29 October 2008, 21:15:05 »
agree a leak is most likely but we were unable to spot it the other day, however i just realised the later cars with maf sensor dont read the boost sensor, its not used!! they only use the measured airflow from the maf???
« Reply #22 on: 29 October 2008, 21:18:00 »
Is that right? As mine runs pretty good with MAF unplugged, but not so hot when I forget to plug in boost pipe!
Omegatoy
  • UK
« Reply #23 on: 29 October 2008, 21:28:42 »
well if you remember we can read the actual boost on mine abut not on yours? and it was you that said the signal from boost sensor is just a constant voltage on the later cars where as mine varies with the differnt boost figures??
« Reply #24 on: 29 October 2008, 21:34:25 »
No, you can read boost pressure on later, its the air temp you can't
Omegatoy
  • UK
« Reply #25 on: 29 October 2008, 22:52:34 »
damn >:(
« Reply #26 on: 30 October 2008, 18:44:13 »
Next week is ABS meet? You going OT? If so, take my tractor for a blast and see if you think performance is down?  Obviously, its your favourite 2 pedal gearbox type, so won't be quite as quick as your beast, but I'm sure you could tell if there is a perfromance issue?
Omegatoy
  • UK
« Reply #27 on: 30 October 2008, 20:14:27 »
no probs buddy as long as i finish work early enough will be there!!! :y
« Reply #28 on: 30 October 2008, 20:21:07 »
Ah, so you'll be there before me then ;D
Omegatoy
  • UK
« Reply #29 on: 30 October 2008, 22:23:34 »
lol not been finishing till 10 at night!!!! bloody m6 is a niotemare!!!!
Pages: 1 [2] 3  All   Go Up
Page created in 0.024 seconds with 16 queries.
