Author Topic: OK It's a crank sensor!  (Read 1113 times)
Martin_1962
« on: 07 November 2008, 22:29:02 »
Right you come to this section and wander what the problem is and 9 out of 10 times it is a crank sensor.
Doesn't start - crank sensor
cut out then restarts when cooler - crank sensor
Spins quickly, doesn't start - crank sensor
Stalls at low revs and struggles to restart - crank sensor
Clonls going over bumps - crank sensor - OK joking here
But this is the main V6 problem from what I can see.
ronnieboy
  • birmingham
Re: OK It's a crank sensor!
« Reply #1 on: 07 November 2008, 22:33:51 »
I pick a new one up from vx dealer tomorrow. Thankls for info regards ronnie
MutantCav
  • Gainsborough
« Reply #2 on: 07 November 2008, 22:50:31 »
Engine suddenly running a bit rough...crank sensor!!
« Reply #3 on: 08 November 2008, 09:08:12 »
or cambelt :'(
« Reply #4 on: 08 November 2008, 09:36:56 »
mine, in 6 months of ownership, has cranked on the key for 5 seconds without firing 3 times! Turn ignition off and straight back on and it fired straight away...
When warm, the idle seems a bit rough intermitently, although speaking to Kevin Wood he says his is the same...
Apart from that no problems, touch wood.
