Pages: 1 [2] 3  All   Go Down
Author Topic: dying tractor  (Read 8291 times)
Re: dying tractor
« Reply #15 on: 01 November 2008, 22:42:41 »
can't get a live from plug that injector 4 is plugged into, but get an earth from 1 of 2 terminals. tommorrow will have to investigate where it is fed from. the plastic box where they meet and the glow plugs are fed from is an awkward place to get to. so will replace glow plugs while i'm at it and will have less chance of needing to access it again once (eventually) it's cured
Its a needle sensor, so that is probably correct
dieseldean
  • chesterfield
Re: dying tractor
« Reply #16 on: 01 November 2008, 22:50:15 »
will try for live at plug for wire to no 4 injector with engine running before having to dig out that plastic thingy full of wires
Re: dying tractor
« Reply #17 on: 01 November 2008, 22:58:04 »
Why do you think there should be a 12v there? It can easily be 0v instead  :-/
dieseldean
  • chesterfield
Re: dying tractor
« Reply #18 on: 01 November 2008, 23:09:48 »
for this my only alternative seems to be replace injector4 or find money and send car to specialist. which will probably cost more than paid for car so i may be looking for a 3rd tractor to fill my driveway.
Re: dying tractor
« Reply #19 on: 01 November 2008, 23:12:46 »
given you have air in fuel, that needs to be resolved. presumably you tried full bleed?
dieseldean
  • chesterfield
Re: dying tractor
« Reply #20 on: 01 November 2008, 23:29:08 »
fully bled from tank to pump inlet.
last weekend i replaced sender/pump unit in tank flushed fuel lines upto filter with compresssed air and then flushed with compressedair from pump back upto filter, relaced filter housing fitted new filter and filled filter with diesel magic to clear pump and injectors.
that was basic old school stuff, but my problems seem to be too technical for me.
i think air must be coming to injectors from fuel pump itself
« Last Edit: 01 November 2008, 23:31:14 by dieseldean »
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: dying tractor
« Reply #21 on: 02 November 2008, 10:12:31 »
Stating the obvious Dean.....
Why not try swopping No4 injector from your other tractor?
dieseldean
  • chesterfield
Re: dying tractor
« Reply #22 on: 02 November 2008, 10:42:57 »
engine already sold from the old tractor :'(
Re: dying tractor
« Reply #23 on: 02 November 2008, 12:27:43 »
The plug on the injector varied between U25TD and X25DT engines as well.
dieseldean
  • chesterfield
Re: dying tractor
« Reply #24 on: 02 November 2008, 22:23:29 »
has anyone reading this thread got an injector no 4 to try or even sell me. can't pay £300ish for a new 1 cos i gotta payout about that to put my front suspension and steering right and the untidy bodywork. looks like i'm on market for another tractor and this one joining my other miggy in the driveway graveyard. :'( :-/ :'(
unlucky alf
  • worksop, notts
Re: dying tractor
« Reply #25 on: 02 November 2008, 23:04:31 »
dont suppose there is anyone on ebay breaking a diesel? are these no4 injectors used on anything else?, as im fairly local to you dean if i find anything or hear of anything i`ll give you the nod, is it definately that injector then & if so how easy is it to get out, i could do with a t/converter & b/housing so i will be looking out for one being broken or complete anyway,,,,good luck :y
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: dying tractor
« Reply #26 on: 03 November 2008, 09:11:02 »
I've got a set of 6 injectors which were checked out by the Bosch agent in Newbury as OK
dieseldean
  • chesterfield
Re: dying tractor
« Reply #27 on: 06 November 2008, 20:16:16 »
 :y :y :ya great big thank you to pitchfork for going out of his way to supply me some injectors :y :y :y
will post my cars health as soon as i can find a deep 27mm 12 pointed socket so i can get them injectors changed :-[
« Last Edit: 06 November 2008, 20:17:40 by dieseldean »
markey mark
  • SLady bitshorpe north lincs
Re: dying tractor
« Reply #28 on: 06 November 2008, 20:19:25 »
i have a injector socket 27mm deep bud !!  :y
dieseldean
  • chesterfield
Re: dying tractor
« Reply #29 on: 06 November 2008, 20:47:47 »
pm sent :y
Pages: 1 [2] 3  All   Go Up
