Author Topic: Water leak in passenger footwell  (Read 4381 times)
Davey
  • Berkshire
« on: 10 November 2008, 10:54:46 »
I was in a convery belt carwash on sunday and some old fart stalled at the end and couldnt start his car so I was stuck under the water spray bit for about 5 minutes.. I started hearing water inside the car and I noticed water dripping from under the dash into the passenger footwell, I turned off the air recirc and suddenly about a litre of water came gushing in and started sloshing about in my footwell..
Has anyone else experienced a leak like this before?  ;D
« Last Edit: 10 November 2008, 10:55:03 by Davey »
Re: Water leak in passenger footwell
« Reply #1 on: 10 November 2008, 11:08:47 »
« Reply #2 on: 10 November 2008, 11:25:52 »
Classic blocked scuttle drain! Right time of the year too :y :y ::) ::)
Davey
  • Berkshire
« Reply #3 on: 10 November 2008, 12:56:00 »
Cheers guys.. It was leaking again just now (we've had really heavy rain)
Lifted the scuttle cover and found this
The drain plug was blocked, with glass! Cut my finger to shit poking it out.. Nice one RAC windscreens  ;D
« Reply #4 on: 10 November 2008, 13:08:49 »
A wet and dry vacuum or stiff wire is probably the best way of making sure the drain is clear :)
Davey
  • Berkshire
« Reply #5 on: 10 November 2008, 13:15:39 »
I'm going to give it a blast with the compressor :)
Welung666
« Reply #6 on: 10 November 2008, 13:18:36 »
WEAR GOGGLES!!! Just in case there is any glass left in there.
« Last Edit: 10 November 2008, 13:18:46 by Welung666 »
Davey
  • Berkshire
« Reply #7 on: 10 November 2008, 13:57:57 »
Yes DAD  ;D  ;)
Welung666
« Reply #8 on: 10 November 2008, 14:01:03 »
 ;D ;D ;D :P
2nddaniel
  • Heywood
  • I swerve for HGV's.
    • Omega 3.0 V6 Elite
    • Cheesey peas
« Reply #9 on: 07 November 2014, 17:11:09 »
That's just happened to me. Rain water when demisters turned on, leaking into passenger footwell. Started removing glovebox, got stuck, looked on this forum and found this post. It must be the blocked scuttle drain. I'll have a go unlocking it.
Weapons officer, prepare to fire.
I am prepared. I'm the weapons officer.
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« Reply #10 on: 07 November 2014, 19:04:42 »
And it can stink like a sewer to :(
woolley11
  • York
    • 3.0 MV6 auto
« Reply #11 on: 08 November 2014, 11:42:48 »
Had same problem - misting windows.
Found damp mat on passenger footwell. The scuttle hole was full of water nearly upto the pollen filter. Even more worrying that a bunch of wires were well under water.
Bung hole was full of leaves and crud - water soon went after all cleared. No more problems  :)
Omega 3.0 MV6 pfl
BMW Alpina B10 3.3 Touring
VW Mk1 Golf GTi Campaign, Triumph Dolomite Sprint
« Reply #12 on: 08 November 2014, 12:58:06 »
Yep....Be skinny of arm. ;D
« Reply #13 on: 08 November 2014, 15:47:25 »
The loom itself is waterproof :y it's only the ends that aren't  ::)
2nddaniel
  • Heywood
    • Cheesey peas
« Reply #14 on: 08 November 2014, 17:46:25 »
Done it. Unblocked it. Water was fresh so didn't stink. Tasted alright too. :-X
