Author Topic: 2.5 refusing to start...  (Read 5274 times)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: 2.5 refusing to start...
« Reply #15 on: 08 November 2008, 22:56:18 »
you have checked the fuses havent you ?????????????
ok then matey i'll have a nosey at the fuel filter and that dust cap tomorrow... tbh no i havn't checked fuses :P
i'll have a look in the morning and post it up then for your investigation lol
thanks :y
V8!!!!
MutantCav
  • Gainsborough
« Reply #16 on: 09 November 2008, 10:46:33 »
3.0 cams are on their way to you mate so you had better get it going soon! lol
ngrainqey
  • rotherham
« Reply #17 on: 09 November 2008, 18:43:00 »
i know chris... it's all one mad rush ahha!
can anybody point me in the direction of the relay- obviously it's in the relay box and the fuel pump fuse is the 3rd one in from the right in the middle row afaik
how easy is the fuel pump to get out?
thanks
V8!!!!
ngrainqey
  • rotherham
« Reply #18 on: 10 November 2008, 22:13:52 »
oh yeah... would a hole in the pipe for the secondary air injection cause it to not start?
it's not on the pipe going to the one way valve but on the other side of the injector if that makes sense (right on the bend in the pipe)
tbh didnt think it was major
thanks
V8!!!!
MutantCav
  • Gainsborough
« Reply #19 on: 11 November 2008, 13:22:03 »
Its a pretty big hole and bound to cause some sort of air leak...certainly cant be helping! lol Got a replacement here if you need it...
markey mark
  • SLady bitshorpe north lincs
« Reply #20 on: 11 November 2008, 14:35:58 »
thanks
it wont matter alex  :y
ngrainqey
  • rotherham
« Reply #21 on: 12 November 2008, 22:17:59 »
Update! update! update :P
riiight then, after some relay masticating and also taking pipes off the fuel pump... its getting fuel! buuuut... it has random missfires on cyl 1 and i think 5... had oily smoke i think it was coming off 5 and 6 at one point (i think it was oily)
anyway had the plenium off to see a big blue flame come out of the inlet haha!
it sounds like its running on about 3 cylinders lmao! not good :P
it's compressing and then decompin on a few cylinders and then firing on a couple so turning over with a couple of bumps of firing.
do you think it's dispack or check spark plugs first? check for oil in plugholes?
thanks
V8!!!!
MutantCav
  • Gainsborough
« Reply #22 on: 13 November 2008, 08:00:05 »
Wellit certainly cant hurt to check for oil in the plug holes anyway as its easy enough to do??
Are you sure the timing is right Alex?
Did you replace the head or is it the old one?? Might be the heads knackered?>?
ngrainqey
  • rotherham
« Reply #23 on: 13 November 2008, 12:26:09 »
i'm on about going to check the oil in plug wells today..
the only reason the timing would be out would be because some moron took the cams out and hasnt bothered to put the pulleys onto the cams properly.
is there a possibility its the dispack/ht leads that are caputted making it spark at the wrong time?
the only reasons i can think of a backfire are... the valve is majorly bent alloying the exploding gases to fire out of the inlet manifold lol! or that its sparking at the wrong time because of the dis pack
thanks
V8!!!!
michael.d.s.
  • glasgow
« Reply #24 on: 13 November 2008, 12:31:36 »
is the coil pack ok , you can use ht lights to check spark at plugs and you can use a noid light to check injection pulse .
ngrainqey
  • rotherham
« Reply #25 on: 13 November 2008, 15:22:24 »
well im thinking the dispack/coil pack could be fubar'd
i dont have a noid light haha!
there's defo fuel going to the fuel rail and theres defo fuel going into atleast cylinder 1
V8!!!!
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #26 on: 13 November 2008, 18:25:19 »
wouldnt it be alot easier to just buy a 2.5!
ngrainqey
  • rotherham
« Reply #27 on: 13 November 2008, 18:26:41 »
i have bought a 2.5 so i'v got a 2.0 shell mostly stripped, a 2.5 lump and a black 2.5 ;) haha!
V8!!!!
