Author Topic: the car eating front tyres up  (Read 3656 times)
razzo
  • Crapital
    • 97 3.0 Elite
Re: the car eating front tyres up
« Reply #15 on: 17 November 2008, 21:54:57 »
might be worth an e mail to tony at wheels in motion, perhaps he could e mail you his recomendations for the omega geometry set up & you could get the locals to set it up as per his recomendations worth a shot
Kaycee
  • Doncaster
« Reply #16 on: 17 November 2008, 22:02:37 »
Get the car on level ground at the front most inportant drop a plum line on yr front wheels measure the difference of the top of rim and bottom it should be around 9 mm  difference at the top thats yr starting point i suspect its mor than this  if its around 15mm yu got trouble bear i mind this is only a preliminary check
There is a tide in the affairs of man if taken at the flood will lead on to greater things
DC
  • Switzerland
« Reply #17 on: 17 November 2008, 22:51:45 »
Thanks to all suggestions. Someone from the forum was kind to supply me with camber values. Now, all I need is to find a reputable place to sort it out.
