Pages: 1 [2] 3  All   Go Down
Author Topic: Code 73 & 74  (Read 3715 times)
Re: Code 73 & 74
« Reply #15 on: 16 November 2008, 18:50:28 »
varies, check the plug on yours
bighed
  • Shropshire
Re: Code 73 & 74
« Reply #16 on: 16 November 2008, 18:57:37 »
where is it on top part of engine? seen it on how to but only from underneath  :y
Re: Code 73 & 74
« Reply #17 on: 16 November 2008, 20:30:59 »
back of babk 2/4/6
bighed
  • Shropshire
Re: Code 73 & 74
« Reply #18 on: 16 November 2008, 21:33:28 »
Thats great! And where would the number be i have to check. Is there any pics of cam sensor from top??  :y
« Last Edit: 16 November 2008, 21:33:49 by bighed »
Re: Code 73 & 74
« Reply #19 on: 17 November 2008, 10:22:05 »
Check the maint guide - the connector can either be more oval or more square.
Richard A
  • Aldridge, West Midlands
Re: Code 73 & 74
« Reply #20 on: 17 November 2008, 10:45:11 »
When the crank sensor failed on my 2.5 I cut the connector off and took it to the dealer to make sure I got the correct replacement.
It is impossible to route the replacement as the factory fitted one, not a problem just keep the cable from anything hot or cold.
regards
richard a
richard a
Re: Code 73 & 74
« Reply #21 on: 17 November 2008, 10:55:49 »
regards
richard a
Not entirely true ::) - I spent hours, and I mean hours, doing it.  It was only a few months after than I learnt there was a better way ;D
bighed
  • Shropshire
Re: Code 73 & 74
« Reply #22 on: 17 November 2008, 14:07:09 »
hi TB, when u say in how to, to check the plug thats the bit on the top part of the engine isnt it? :y
Re: Code 73 & 74
« Reply #23 on: 17 November 2008, 14:51:12 »
yes
MutantCav
  • Gainsborough
Re: Code 73 & 74
« Reply #24 on: 17 November 2008, 17:29:12 »
Only one crank sensor for v6 in general...however 2 different types of connector as per normal Vaux thinking...an oval connector and a square one...make sure you get the same connector...
It plugs in down at the bottom of the engine passengers side towards the back by the oil filter...and runs up to a plug the other end which you can find near the back of the plenum
« Last Edit: 17 November 2008, 17:29:42 by ShieldOfSteel »
bighed
  • Shropshire
Re: Code 73 & 74
« Reply #25 on: 17 November 2008, 18:23:49 »
 :y :y :y :y :y :y :y :y Thanks both
bighed
  • Shropshire
Re: Code 73 & 74
« Reply #26 on: 17 November 2008, 22:31:22 »
 :-/ :-/ :-/ :-/ :-/ :-/  Really confused now. Just been and paperclipped her again after a decent drive and only got code 31?? :-/ :-/ :-/ :-/ :-/ :-/
« Last Edit: 17 November 2008, 22:45:52 by bighed »
bighed
  • Shropshire
Re: Code 73 & 74
« Reply #27 on: 18 November 2008, 11:53:36 »
any ideas  :-/
markey mark
  • SLady bitshorpe north lincs
Re: Code 73 & 74
« Reply #28 on: 18 November 2008, 13:47:35 »
any ideas  :-/
leave it then and check it again in a few weeks  :y
bighed
  • Shropshire
Re: Code 73 & 74
« Reply #29 on: 18 November 2008, 21:31:12 »
thats what Im thinkin..... Thanks to everyone for the help!!!!!  :y
Pages: 1 [2] 3  All   Go Up
