Author Topic: HELP!! LOCKED OUT OF MY MIGGY!!!!!!!  (Read 4177 times)
Re: HELP!! LOCKED OUT OF MY MIGGY!!!!!!!
« Reply #15 on: 18 November 2008, 21:42:09 »
How do I get in through the bonnet?? You lost me!! :-? :-?
Squeeze ;D ;D
A1TNL
  • THATCHAM
« Reply #16 on: 18 November 2008, 21:54:38 »
I agree with the forcing the key in the Lock, my battery went flat and i could not get in, i thought if i forced it any more the key would break so i phone the AA.
He came out and just forced the key and pulled the handle and hey presto!
Sometimes brute force and ignorance is the answer
GuzziHero
  • Stoke-on-Bloody-Trent
« Reply #17 on: 19 November 2008, 08:36:38 »
Forcing it hard is the correct answer.  I would personally use silicon spray lube rather than WD40 as I believe WD40 might corrode any rubber seals in there, whereas silicon makes them expand.  Thats what I've been told anyway.
Either that or act any local hoodlum...I'll bet they know a way in fast enough.
lou
  • Romford
  • Always expect the unexpected
« Reply #18 on: 19 November 2008, 15:24:47 »
Hi, I had same problem with my lock, I tried and tried, then got into the car through the boot and drove the car to the garage. I felt a right prat ???? when the bloke said how easy it is and proceeded to open the door for me. Turn to the right (Clockwise) but very hard, it feels the key will snap but it does not. ...keep trying...good luck
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #19 on: 19 November 2008, 17:15:18 »
Just to re-iterate, WD40 is NOT a lubricant!
I like red cars
bobbertbear
  • perth
    • 04 omega 3.2 ex plod
« Reply #20 on: 19 November 2008, 20:06:11 »
i had this problem on my w reg facelift,it turned out the little bar from the barrel to the lock was off,but only found that out after having to break my grill to get the bonnet open to put jump leads on,for the next time the battery went flat,even with it deadlocked,i still managed to open it with the key. :)
