Pages: 1 2 [3]  All   Go Down
Author Topic: v6 flywheels...  (Read 6662 times)
Re: v6 flywheels...
« Reply #30 on: 20 November 2008, 21:39:08 »
oh yeah... from looking at a flywheel on the omega it looks rather like just a solid plate with six bolt holes in the centre and 6 mountings for the torque convertor
LOL, if its an auto, no flywheel!
 ;D
yep..a small detail..
Re: v6 flywheels...
« Reply #31 on: 20 November 2008, 21:40:00 »
buy something like
will do the job..
Engine Porn!  ;D ;D ;D ;D
some like it different ;D :y
Ian_D
  • York
Re: v6 flywheels...
« Reply #32 on: 20 November 2008, 21:41:29 »
I thought that!  ;D
How heavy is the torque convertor? Im sure my Auto Omega revs up quicker than my Man 2.5 Vectra gsi  :-/
[size=12]
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: v6 flywheels...
« Reply #33 on: 20 November 2008, 21:43:02 »
its a DMF flywheel so it cant be lightened can it???
MV6's is DMF anyway i assume they all are
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: v6 flywheels...
« Reply #34 on: 20 November 2008, 22:00:17 »
Correct....a lightened flywheel only help an engien on a dyno........when connected to a gearbox, prop, read diff and then a 1.7 ton car....they make break all difference!
Plus, you wont take any weight off an Omega flywheel as its a complex multi piece dual mass setup!
As for the exhaust maniofld to head matching....they are already matched!
riiight.... what about opening up the ports to the exhaust manifold and matching the bore in the manifold? (obv would need sports exhaust etc to get benefit)
Stick a supercharged V8 in there and have done with it!  ;D ;D ;D ;D
lol i'm going to invest time money and patience in a v8 omega project but not this minute
i want to work upto a big project like that haha!
i'v thought about a twin turbo project :P but need to be arsed to buy two t25 garret turbos haha!
Where can I find T25's cheap???  ::)
go on uksaabs.co.uk i think or .com
all the 9000 turbos have t25's... probs just need new bearings haha!
V8!!!!
ngrainqey
  • rotherham
Re: v6 flywheels...
« Reply #35 on: 20 November 2008, 22:03:02 »
might do away with the multiram, get an induction kit then bolt two t25's on :P
just have to find the right head spacer plates haha!
think it'll want the 2mm ones (and yes i'v been asking about to do with turboing the omega) apparently you need a piggyback or standalone ecu for the fueling
V8!!!!
Re: v6 flywheels...
« Reply #36 on: 20 November 2008, 22:10:19 »
if you dont decrease the compression ratio and arrange the pressure of turbo I think you cant reach even 4500 RPM :-/
and the last thing you hear will be a bang!
Re: v6 flywheels...
« Reply #37 on: 20 November 2008, 22:15:08 »
Check the engine is strong enough - seem to remember its not.  I think the 3.2 has steel crank, that may help
Ian_D
  • York
Re: v6 flywheels...
« Reply #38 on: 20 November 2008, 22:16:58 »
Oh Dear, Oh Dear, Oh Dear.... Whys everything have to be complicated  :'(
[size=12]
ngrainqey
  • rotherham
Re: v6 flywheels...
« Reply #39 on: 20 November 2008, 22:23:14 »
the turbos are fine at 6psi with standard mapping...but could do with mapping better..
and it's called engine lockup :P
it's fine aslong as the comp ratio isnt too high so need some spacer plates unless i just intend on using it upto 6psi (which i dont if i do it right :P )
V8!!!!
ngrainqey
  • rotherham
Re: v6 flywheels...
« Reply #40 on: 20 November 2008, 22:26:00 »
..right bed time!
cya later
V8!!!!
Re: v6 flywheels...
« Reply #41 on: 20 November 2008, 22:29:52 »
Dream of little flywheels and big turbos. :y ;D ;D
Pages: 1 2 [3]  All   Go Up
