Author Topic: Dodo dead  (Read 1896 times)
Dubious
  • Nearer Swindon than Brisbane
Dodo dead
« on: 23 November 2008, 16:23:09 »
2000 Omega estate (facelift, but with 2.5 V6).
Not used it for 4 weeks, and now I can't get in. The light flashes on the remote, but it doesn't unlock. Doesn't unlock with the key either. I'm presuming that the battery is flat (it's relatively new, so I'm assuming I left something switched on). But surely the door would unlock even with a flat battery ??!?
What can I do ? I'd rather save my RAC visits for the VW camper !
Thanks
kevpuk
  • Poole
Re: Dodo dead
« Reply #1 on: 23 November 2008, 16:26:21 »
Figured you should still be able to open the drivers door 'mechanically' with they key....irrespective of battery charge.....perhaps not the battery ?
Re: Dodo dead
« Reply #2 on: 23 November 2008, 16:26:42 »
The key in the door will work, its very hard to turn, so much so that you would think the key will brake, but it should open ;)
Dubious
Re: Dodo dead
« Reply #3 on: 23 November 2008, 16:29:00 »
Thanks for the reply. That's what I thought, but can't think of a way to test it at the moment. And I was away on holiday, so would have checked pretty carefully. But if not the battery, then what ?
Re: Dodo dead
« Reply #4 on: 23 November 2008, 16:31:28 »
As "Elite Pete" says. Force the key to unlock it then you can check whether it`s the battery :y
Dubious
Re: Dodo dead
« Reply #5 on: 23 November 2008, 16:32:18 »
That's turning clockwise to unlock ? Serious 'brave pill' intake required to turn it just short of breaking.
Re: Dodo dead
« Reply #6 on: 23 November 2008, 16:34:32 »
Yes. You will be expecting the key to snap but just force it  :y
Dubious
Re: Dodo dead
« Reply #7 on: 24 November 2008, 09:10:36 »
Thanks for the help. Worked rather more easily than I feared ! It is a dud battery, but I've got a power pack, so should be on the road in no time.
Thanks again.
Re: Dodo dead
« Reply #8 on: 24 November 2008, 09:29:35 »
Thanks again.
It does make your bum twitch a bit, but does work ;)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Dodo dead
« Reply #9 on: 24 November 2008, 12:07:42 »
Moral to this tale, open the door from time to time with the key, keeps it free :y
I like red cars
oceansoul
  • Sunbury on Thames - Surrey
Re: Dodo dead
« Reply #10 on: 24 November 2008, 12:25:43 »
i cant remember if this is on the omega or corsa (i read it either here or on corsasport) but u can just about get under the car, and get a set of jump leads on the starter motor terminals, and hook up a second battery. That way you can open the car :p
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: Dodo dead
« Reply #11 on: 24 November 2008, 15:42:17 »
A flat battery on the car will stop the central locking from working, so open the car with the key and get in close the door and try to start the car , if the car starts then the problem is the fob, it may just need re connecting to the car,
 1 put the key in the igniton and turn the barrel till the ign lights come on [dont crank the starter]
2 press the lock button on the fob and the locks should lock then unlock.
3 remove key from ignition lock and try to lock the car as normal with the fob, [this should work 9/10 times.]
If it does not work then try a new battery in the fob , then you may have to get a new fob. Hope this is of some help to you.
I had the same problem but eventually i had to replace the fob and I have had no problems since.  ::)
Jaguar XJ6
dippydave
  • Sutton Coldfield, West Mids
  • how personal?
    • Vectra 2.0DTi Elite
Re: Dodo dead
« Reply #12 on: 24 November 2008, 20:19:51 »
i've had battery's go dead on me very often and have never been brave enough to force the drivers lock. i always thought it wouldn't open due to the deadlocks holding it!
anyway, my remedy has been to open the saloon boot with the key (always simple....touch wood.)
Then i've either
- pushed the ski hatchdown (never lock it from the inside me!) put a hand through and dropped the seat, then crawled through and popped the bonnet. then an assistant puts a charger on the battery and i can get out properly - that or climb back through the boot to do it meself!
or - realised that an easier way to get juice to the battery is to pop the boot light out and attach a bog standard car charger to the lamp terminals! This gets enough juice to the battery to enable the central locking to work and then doors'll open normally, bonnet can be released and a nice charge given overnight.
 :y i really have done this too many times!
Vectra Elite Estate doing good post-Omega service but still not as nice to sit in.
One last Omega on the drive, one Corsa on the lawn...maybe they'll go to a good home before too long!
Re: Dodo dead
« Reply #13 on: 24 November 2008, 20:25:12 »
.....or - realised that an easier way to get juice to the battery is to pop the boot light out and attach a bog standard car charger to the lamp terminals! ......
Which is how I got in my car when the battery died a death. It doesn't work with a facelift though .... nowhere to put your key in a face lift saloon's boot!  ;)  :y  :y
dippydave
  • how personal?
Re: Dodo dead
« Reply #14 on: 24 November 2008, 20:27:30 »
oh yeah.. that stupid button thing. I knew there was another reason i don't like facelifts!!
Page created in 0.028 seconds with 20 queries.
