Author Topic: Multi-ram Actuator  (Read 2388 times)
gwa
  • Peterborough
  • Ginger With Attitude
Multi-ram Actuator
« on: 15 November 2008, 18:43:58 »
I've read. but probably not fully understood Marks DTM explanation in the Maintenance Guides.
I've been told that you should hear an audible click/clonk from  the actuator at certain revs (above 3.5k etc).  Mine does 'diddley squat!! So:
1 If correctly fitted what else could be the problem?
2 If not correctly fitted what should I do over & above what's in  the guide. AHA, Ta  :)
If it ain't fun, it ain't worth doin
markey mark
  • SLady bitshorpe north lincs
Re: Multi-ram Actuator
« Reply #1 on: 15 November 2008, 23:00:10 »
have had/seen them go faulty ! also worth checking your vac lines are fitted correctly !  :y
serek
  • huntingdon
    • 3.2 mv6
« Reply #2 on: 15 November 2008, 23:12:21 »
then what if all vac lines conect correctly ?
markey mark
« Reply #3 on: 15 November 2008, 23:13:09 »
faulty actuater :y
« Reply #4 on: 16 November 2008, 01:18:11 »
faulty actuater :y
the audible click, i am fairly sure can only be heard with engine off when activated via tech 2.I've seen the boy and Kevin Wood do similar to check operation. Or stand by the open engine bay and blip the throttle body, you should see them move, vacuum and electrickery operated iirc.
hth
 whats your mpg like out of interest?
serek
  • huntingdon
    • 3.2 mv6
« Reply #5 on: 16 November 2008, 02:08:10 »
long run 70-75mph 28mpg, round town 15.8
ones only was more then 30mpg but that was 100 miles trip and driving up 70mph
« Reply #6 on: 16 November 2008, 02:48:40 »
bit low, round town esp, or are you raging it a bit? Should be able to get 18 in town while driveing "normally" carefull feet should give 21 ish imho, so maybe multi ram bit poorly, as you suggest?
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #7 on: 16 November 2008, 11:45:18 »
I have had a poor performance issue with my car for quite a long time. I had checked and rechecked the multitude of vac pipes and connectors. I even replaced some.
Two days ago I checked them all again and found a split under the U shaped rubber pipe from the rear multiram to the electrical connection. I am fairly convinced that is what has been causing my troubles but haven't been able to test it as the gearbox is Kaput.
It might be worth double checking yours.
varche
Jimmy Jerms
  • Kent/London Border
« Reply #8 on: 16 November 2008, 11:45:27 »
It would be helpful if people spoke English on these pages.
Whats Tech2 and iirc?
Welung666
« Reply #9 on: 16 November 2008, 11:54:55 »
LOL Tech2 is a Vx diagnostic computer and IIRC = if I remember correctly :y
gwa
  • Peterborough
« Reply #10 on: 16 November 2008, 12:53:00 »
I know just how you feel, so when visiting this or other sites I also have this open.. http://www.internetslang.com/
 :y :y :y :y :y
BTW HTH and YMW  ;D ;D ;D ;D ;D ;D ;D ;D
« Last Edit: 16 November 2008, 12:53:24 by gwa »
« Reply #11 on: 16 November 2008, 17:13:48 »
Jimmy Jerms
« Reply #12 on: 25 November 2008, 19:15:19 »
Well!!
There you are. I must be getting old. I punctuate text messages.
TAL  (thanks a lot). :(
Page created in 0.024 seconds with 20 queries.
