Pages: 1 2 [3]  All   Go Down
Author Topic: extra v6 cooling...  (Read 6645 times)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: extra v6 cooling...
« Reply #30 on: 26 November 2008, 18:35:36 »
I'm sure my 2.5 V6 has two fans (infront of the rad) and one the the rear left had side, so three in all.
mine has a single front one :(
V8!!!!
Techno
  • Bedfordshire
« Reply #31 on: 26 November 2008, 18:57:39 »
What year/model is yours?  Mine is 97 2.5 V6 CD I would have thought all V6's would have been the same or my be it's different for earlier models.
Just out of interest have you raised this because yours has a cooling issue or just that they run hot?  I say that as mine and others I've seen run at between 90* and 95* on the temp gauge and that is hotter than most other cars I've owned others running at a little over 80*.
ngrainqey
  • rotherham
« Reply #32 on: 26 November 2008, 19:04:17 »
im just wanting to reduce the engine temp at normal running really for using a garret turbo :P
btw mines a '94
this is what i had in mind (the bonnet inlets)
« Last Edit: 26 November 2008, 19:06:29 by grainqey »
V8!!!!
ngrainqey
  • rotherham
« Reply #33 on: 26 November 2008, 19:10:11 »
this shows the vents better
V8!!!!
Techno
  • Bedfordshire
« Reply #34 on: 26 November 2008, 19:11:56 »
I see, well if mine runs at over 90* with 3 fans and your runs the same with 2 does it?  Fitting an extra one should reduce the running temp but by how much can't say.
You could as I think you and other have suggested fit bonnet louvers I had these on my old Cosworth and they really work, mate at the time replaced his bonnet (due to damage) with a standard one while awaiting repair the heat shot up so they do work.  :)
They worked more by sucking the heat out rather than forcing air in the good old vacuum effect, they are other ways but with the Omega we are very limited with under bonnet space.
How about increasing the size of the oil cooler?
« Last Edit: 26 November 2008, 19:16:06 by Techno1 »
ngrainqey
  • rotherham
« Reply #35 on: 26 November 2008, 19:20:37 »
well im adding an external one instead ;)
V8!!!!
Pages: 1 2 [3]  All   Go Up
