Author Topic: Cant Ulock Doors - Flat Battery  (Read 2081 times)
Tonnee
  • Bolton, Lancs
« on: 01 December 2008, 12:01:33 »
Help
I cant get into my omega, I lock it using the deadlocks and the battery is now completly flat after being stood several days, the doors just wont unlock with the keyfob or the key !!
What do I do ??
Tony
Vauxhall Omega Tourer 2.5 V6, Suzuki GSXR 750 WR
Re: Cant Ulock Doors - Flat Battery
« Reply #1 on: 01 December 2008, 12:02:30 »
It should unlock with the key in the drivers door.....it will be bloody stiff but can be done!
Tonnee
  • Bolton, Lancs
« Reply #2 on: 01 December 2008, 12:04:54 »
I felt like I was going to snap the key yesterday when I tried to force it, it just wouldnt budge.
I'll give it another go tonight when I get in though.
bappy
  • HAVANT, Hants
  • Don't fart on the leather upholstery!
« Reply #3 on: 01 December 2008, 12:50:40 »
does the boot lock with the deadlock?
my driver door lock does not match my key at all.
I've always been able to get in by opening the boot (with the key), kicking in the cubby hole that lets you get to the boot from behind the armrest then reaching up through the gap to find the rear seat release and clamering through from there.
Mines a saloon btw
If at first you dont succeed, Rev it harder!
Tonnee
  • Bolton, Lancs
« Reply #4 on: 01 December 2008, 14:36:08 »
Its the estate Tourer and the boot lock is also deadlocked, that was my first though get in through there....but no :-(
Surely Vauxhall wouldnt make it so as you can't get in once deadlocked if the battery goes flat !!!   would they ??  >:(
« Last Edit: 01 December 2008, 14:36:45 by tonnee »
hatilgan
  • TURKEY
« Reply #5 on: 01 December 2008, 19:56:02 »
Insert the key vertically into the drivers side door. Turn the key left side slowly then turn right back slowly until the key become vertical and initial position.(Note: Do not turn right side fully!) If it does not work try the opposite direction..
« Reply #6 on: 01 December 2008, 20:38:14 »
In theory .... no! In practice, there was no way my key was going to get into my deadlocked car  :(. I used the boot light to power up the car, but as yours is an estate and can't get in via the tail gate, how about crawling under the front and attaching your 12 volts to the starter motor?  ;)  :y :y
Tonnee
  • Bolton, Lancs
« Reply #7 on: 02 December 2008, 10:40:10 »
Hooray, got in it last night, I just forced the key, didnt actually need that much forcing to be honest so I can get in now :-)
I think it was more the apprehention of forcing the key originally, it just didnt seem right to force anything!
Thanks Guys
Bacon Butty Man
  • Cleveleys Nr Blackpool
  • now own a Laguna 2
« Reply #8 on: 02 December 2008, 13:18:07 »
Thanks Guys
Great, i was going to suggest a brick
my Rover 75 Club SE
« Reply #9 on: 02 December 2008, 14:31:36 »
Thanks Guys
It is worrying, but the car will unlock before the key snaps ;)
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #10 on: 02 December 2008, 19:56:33 »
Thanks Guys
Great, i was going to suggest a brick[/quote]
You must have seen the old likely lads comedy programme , egged him onto smash the window with a brick only to find the door was nt locked :y
Page created in 0.026 seconds with 20 queries.
