Author Topic: heater problems  (Read 1721 times)
nick v6
  • walsall / west midlands
heater problems
« on: 05 December 2008, 18:33:53 »
i noticed today for the first time
i had cold feet so i turned to dial for the hot air to blow to my feet and nothing happened
mine is a 94 2.5v6 cdx
the dial will turn to all the positions but only seems to blow out at the screen
ive got my dumb head on today hope u can all understand the problem i got with the heater
Re: heater problems
« Reply #1 on: 05 December 2008, 18:51:45 »
initially, check the vac layout in engine bay...
nick v6
Re: heater problems
« Reply #2 on: 05 December 2008, 18:55:06 »
where do i find that
ive noticed that when i start the car on the morning i here like an extra motor running and a slight hissing noise which only last about 20 seconds then stops
it seems to be coming from the n-s-f area of the car
Re: heater problems
« Reply #3 on: 05 December 2008, 18:58:49 »
The noise is SAI and unrelated.  Check MDTM post in maint guides re vac layout under bonnet
nick v6
Re: heater problems
« Reply #4 on: 05 December 2008, 19:01:01 »
ok ill try and find it now
nick v6
Re: heater problems
« Reply #5 on: 05 December 2008, 23:59:12 »
wat is this
vauxfan2k
  • Western Isles
Re: heater problems
« Reply #6 on: 06 December 2008, 00:18:38 »
I also have the same prob with my blower only working on the screen (95 model), I put it down to the vacum pipes being put on the wrong way when garage did my rocker covers and dis pack.
If i knew the correct layout i would fix mine also, but my other v6's are post 96 which had a different setup.
« Last Edit: 06 December 2008, 00:19:22 by Vauxfan2k »
nick v6
Re: heater problems
« Reply #7 on: 06 December 2008, 06:18:56 »
the layout is on the site looks a bit complecated
mite have to print it off and study it
shame u dont live closer we could of put the cars side by side and sorted them both out
2 heads r better than 1
