Pages: [1] 2 3  All   Go Down
Author Topic: Omega 2.5 C6 CDX Woes.................. Any help.  (Read 5006 times)
Bobthebuilder68
  • West Midlands / Herefordshire
« on: 05 December 2008, 20:03:37 »
Ive bought a 2.5 CDX V6 Manual V plate, it has a couple of issues so thought i would come here for some advise, so any would be greatfully appreciated.
1. Power steering, at low revs there is basically no power steering once above 1,000 rpm it works... any ideas?
2. The individual heat controls are not illuminated? again any ideas?
3. Stereo, it has steering wheel controls and a multi changer in the boot but the head unit is also a cd? when i turn it on the display comes up as safe? and the head unit makes funny noises the steering controls dont seem to do anything? any help again be appreciated
Drives like a dream, and im impressed..! :-)
MutantCav
  • Gainsborough
Re: Omega 2.5 C6 CDX Woes.................. Any help.
« Reply #1 on: 05 December 2008, 20:08:02 »
1...not sure
2...sounds like the bulbs have gone behind it...does it have climate control??
3...doesnt sound right, whats the head unit, presumably a CDC2 in the boot...cant imagine it would be normal to have a CD head unit and a CD changer unit in the boot...
« Reply #2 on: 05 December 2008, 20:13:13 »
1) Tired PAS pump - solution, replace.
2) Replace bulbs - guide in Maint Guides section
3) Someone has changed the HU. HU needs code entry.
Bobthebuilder68
« Reply #3 on: 05 December 2008, 20:14:36 »
Im new to this...  so bear with me...
Climate control??? it has seperate heater controls for left and right another in the middle for speed and a forth for where you want the wind to go basically..  lol
Stereo looks like a cdr 500 from what ive seen on ebay, cant see it having a single cd in the front and a multi changer in the boot, my old cdx had radio tape infront changer in the back, i expected the same.
MutantCav
  • Gainsborough
« Reply #4 on: 05 December 2008, 20:14:53 »
What head unit is meant to be in a V reg CDX TB??
« Last Edit: 05 December 2008, 20:15:23 by ShieldOfSteel »
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #5 on: 05 December 2008, 20:15:33 »
1. could be low steering pump reservoir level!
2.could be the bulbs (have a few that work)
3. what chris says basically... you shouldnt have a cd head unit afaik with the cd changer at all.. should be a cassette head like the ccrt700 or the sc804 (like i have) lol!
sorry tb.. egnore my post lol...*bows down* lol
« Last Edit: 05 December 2008, 20:18:02 by grainqey »
V8!!!!
MutantCav
  • Gainsborough
« Reply #6 on: 05 December 2008, 20:19:00 »
They stopped putting the SC804 in Omegas after about 96-97 Alex lol
Maybe a CCR600?? Unless they were upgraded too in the V reg ones...
ngrainqey
  • rotherham
« Reply #7 on: 05 December 2008, 20:19:54 »
lol... ok chris i stand corrected :P i was using it as an example tbh
V8!!!!
MutantCav
  • Gainsborough
« Reply #8 on: 05 December 2008, 20:21:15 »
Does it have digital controls or manual ones?? Digital will be climate...
Head unit certainly isnt right...but should be easy enough to replace for the right one :)
Bobthebuilder68
« Reply #9 on: 05 December 2008, 20:24:00 »
the heater controls are all digital,
hadnt thought of pas level.. :-( now i feel thick...
Just be nice to have a head unit that worked in conjunction with the cd changer and the steering controls amazing car for the money
MutantCav
  • Gainsborough
« Reply #10 on: 05 December 2008, 21:12:05 »
Easy enough to replace the bulbs so dont worry...
Depending upon which head unit you should have I may well have one here with the code...
Bobthebuilder68
« Reply #11 on: 05 December 2008, 21:24:36 »
easy enough for someone to change the bulbs who knows there way round an omega.. for me not so good...
Head unit i just want one to control the multi changer and be controlled by the steering controls, long as it works im happy..
ngrainqey
  • rotherham
« Reply #12 on: 05 December 2008, 21:27:52 »
to get to the dash bulbs you take the dash off, even in the digital dial/adjusters setup it's very similar to with control knobs...
you need to take the ash tray out first to get it off (if my memory serves me right)
V8!!!!
Bobthebuilder68
« Reply #13 on: 05 December 2008, 21:31:26 »
take the dash off???? the whole dash??? urrggghhhhh :D scared already....
MutantCav
  • Gainsborough
« Reply #14 on: 05 December 2008, 21:36:53 »
Dont worry Bob just the centre console bit that holds the climate controls in place lol
Removing the ashtray is 3 screws...remove the stereo (which it sounds like you need to do anyway so you can have the correct one in) and then tug on the correct metal bar that holds it all in place...a fairly thick square bar thats behind some of the wiring behind the stereo you pull it down (maybe with the aid of a screw driver) and the whole centre console pops out :)...but do NOT pull the thin metal round bar that runs across there cos its not the one you need and will dislodge! lol
« Last Edit: 05 December 2008, 21:38:56 by ShieldOfSteel »
Pages: [1] 2 3  All   Go Up
Page created in 0.023 seconds with 20 queries.
