Author Topic: Fitting ngk iridium plugs to 3.2 v6  (Read 5132 times)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: Fitting ngk iridium plugs to 3.2 v6
« Reply #15 on: 07 December 2008, 12:45:55 »
well all i can say is that according to parkers the auto 2.0 is only supposed to do 121 ish which i found to be true and then when i swapped them to the denso plugs i had 130 an i'd seen 125 a few times without half as much effort! so maybe it was plugs being buggered but i know something.. when i changed them and started it i got alot of oil burnt off!
V8!!!!
« Reply #16 on: 07 December 2008, 12:47:37 »
I'm with the others - if you noticed an improvement, it was because your old plugs were shagged.  Much like fitting some new super duper wiper - it must be a better design as you can now see in the rain ;)
Saying that, I do fit iridium plugs to her Rover, but that is because that is what they specify for some reason...
« Reply #17 on: 07 December 2008, 12:48:46 »
K series cylinder temps are stupidly high.....its yet another one of the many things that helps insure they always have fresh head gaskets!  ;D
« Reply #18 on: 07 December 2008, 12:53:12 »
According to people in the know, that is the primary reason for HG failure - apparently its run right at the temp limit before some kind of reaction happens between head/block/gasket.
ngrainqey
  • rotherham
« Reply #19 on: 07 December 2008, 12:55:22 »
why not just use those twin spark(like on alfa's)/twin electrode spark plugs on her rover TB
V8!!!!
« Reply #20 on: 07 December 2008, 13:03:21 »
I shoved in what the manufacturer specifies ;) - K series is an engine you stick to what Rover says ;)
Oddly, possibly unrelated, but the pot on which her HG failed was the one that had a faulty plug....
ngrainqey
  • rotherham
« Reply #21 on: 07 December 2008, 13:13:32 »
lol fair enough!
could have been compression related as to why the hg went then
V8!!!!
« Reply #22 on: 07 December 2008, 13:36:34 »
Totaly different setup....they have two spark plugs (although some have the equivalent of two plugs integrated into one)...and hence two sparks per cylinder
