Pages: 1 [2] 3  All   Go Down
Author Topic: Tech 2 Equivalent?  (Read 5460 times)
benbrunt
  • Oldham
Re: Tech 2 Equivalent?
« Reply #15 on: 06 December 2008, 11:38:40 »
The "My Naff Code Reader" I bought a while back can programme keyfobs, immobiliser and the airbag system and for the sake of the £20 I paid was well worth it from ebay.
The only system it point-blank refuses to work with is the climate control system
Sounds like the one with the illegal software  :-X
I'm shocked  :o   ;)
<marquee>[img name=signat_img_resize]http://farm4.static.flickr.com/3208/3130811192_b672fbed66_m.jpg[/img]
Gas Guzzler, I love the stuff!
« Reply #16 on: 06 December 2008, 11:49:08 »
Yeah, expect to pay just shy of £3k for one brand new, or around half that for 2nd hand.  Add around £300-500 for CANdi if required.
what is CANdi?
also..TB do you mind having a nosey on ebay at cheapo tech2 units for under 100 pounds just to see what you think would be the best one for us that want a cheapo solution to tech2 with most of the vital abilitys?
if you can then thats great, doesnt matter if you cant
thanks anyway :y  the thumbs up doesnt get a hat! haha!
Newer Vx models - Astra-H, Zafira-B, Veccy-C, Signum - use a different protocol called CAN.
In CAN, the nearest ECU to the device deals with it. For example, the bulb failure is not an ECU in itself - the rear brakelights are dealt with by the tailgate ECU.  There is no central locking ECU - the BCM tells each door ECU to lock/unlock etc.
CANdi is the adapter that allows the Tech2 to join this network of ECUs.
As to diag tools for Vauxhalls under £100:
Generic ODBII for 2.2/2.6/3.2 (will do engine only).
Cheapo Tech2 if you have a laptop with COM port (flakey as hell, simple code reads and resets only).
Beyond that, you're looking at Opelscanner or whatever its called this week, around £400.
Nothing but a real Tech2 will give you anywhere near the functionality of a real Tech2 - £3k new.
« Reply #17 on: 06 December 2008, 11:54:05 »
And later Corsa C....which has a mix of CAN and ISO!
« Reply #18 on: 06 December 2008, 12:33:22 »
For OBDII cars only ..... 2.6 /3.2 ....
For engine/transmission code reading and EML resetting, with a small amount of live data reading, but NO reprogramming at all the Maxscan GS500 is a reasonable piece of kit, it has certainly done all I've wanted to do so far.
I wouldn't trust myself with anything as complex as a Tech2 without a fewe months trianing by TB or MarkDTM !!!  Seems to me in the hands of an idiot ( me and/or stealers) it is either useless or dangerous !!!!
Maxscan GS 500 is around £80 for a GENUINE AutelTech one ... fake copies that don't have all the bits and don't work as well are cheaper on fleabay .. but I had to send it back ... then bought a "real" one .. :)
http://www.ecufix.com/shop/index.php?main_page=product_info&cPath=69&products_id=206&zenid=4lboqgmfar6evi815sv5hv7vn4
« Last Edit: 06 December 2008, 12:55:29 by entwood »
bikers1
  • Scotland
« Reply #19 on: 06 December 2008, 13:04:38 »
Do any of these eBay thingys read the 2.5 V6 '98 ?
« Last Edit: 06 December 2008, 13:05:04 by bikers1 »
Bikers1.com
Omega 2,5CDX Auto, Shogun 2.5TD, 1.6 Vitarahahah  Biscuit Tin, several self built choppers, old faithful FJ12, Chopped XVS650 Lowrider
benbrunt
  • Oldham
« Reply #20 on: 06 December 2008, 13:18:05 »
The "My Naff Code Reader" stuff on ebay will go back to 1998, mine is a usb only system and works ok without a com port without the need for adapters etc
« Reply #21 on: 06 December 2008, 23:56:04 »
For under £100, cheapo tech2 is your only option - but for engine only, remember the free paperclip test ;)
« Reply #22 on: 06 December 2008, 23:56:30 »
But a legal version is £400 ish :(
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #23 on: 06 December 2008, 23:59:53 »
for me tb it's only really the fault code reset that i'm interested in (so i can reset it and see which are current/saved codes
thanks for info
V8!!!!
« Reply #24 on: 07 December 2008, 00:01:20 »
thanks for info
cheapo tech2 then, but you need a lappy with real com port, and accept the software is flakey
ngrainqey
  • rotherham
« Reply #25 on: 07 December 2008, 00:03:58 »
is the plug and play handheld stuff not ok?
can get one an a 10 pin aldl cable or whatever it is for 50 :(
V8!!!!
« Reply #26 on: 07 December 2008, 00:21:00 »
the handheld sub £100 stuff is all obdii, thus as much use as a used condom smeared in dogshit to you.
« Reply #27 on: 07 December 2008, 00:38:40 »
 ;D The Boy is back.   ;)
« Reply #28 on: 07 December 2008, 00:47:06 »
exquisite explanation ....   :y :y :y :y
 ;D ;D ;D ;D ;D ;D
Albatross
  • Bedford
  • An LSD &amp; an S2000!
« Reply #29 on: 07 December 2008, 08:31:09 »
So is "a condom smeared in dogshit" much use for my 3.2?
What can I do with one, given I have an OBDII car?
Which model is good?
How much roughly?
Where from?
Pages: 1 [2] 3  All   Go Up
