Author Topic: Heating vents  (Read 1726 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
Heating vents
« on: 11 December 2008, 15:59:43 »
Just to check if this is right
I seem to get most of the heat from the side vents in my car when they are opened to the max. Get some for mid vent but not as much ...is this right or is there somthing to look at
Thanks
Steve.
markey mark
  • SLady bitshorpe north lincs
Re: Heating vents
« Reply #1 on: 11 December 2008, 16:03:18 »
try a reset bud ! poss needs a software upgrade  :y
SP_3.2
  • Leicester
Re: Heating vents
« Reply #2 on: 11 December 2008, 16:04:13 »
 Cool will give that a go.
Thanks
Mark :y
Re: Heating vents
« Reply #3 on: 11 December 2008, 16:12:00 »
that confirms nothing wrong with mine as its exactly the same. Have double checked with Kevin Wood and tech 2 and mine has the latest software and, as you say, no usefull flow from the centre vents. You may well find the blast comes back when you use the lower temp settings and the ac chimes back in. Nout to do but hope for another software update.
 Haveing said that the reset wont hurt, for some reason mine only works with the ignition in position 2 engine off position. Hth
Pippin
  • Birmingham
    • Vauxhall Signum 1.9CDTi
Re: Heating vents
« Reply #4 on: 11 December 2008, 17:16:59 »
Silly question, but how do you reset it?
RoSPA Gold Advanced Driver
Trade Card Holder
markey mark
Re: Heating vents
« Reply #5 on: 11 December 2008, 17:17:49 »
hold auto and off for 10 secs  :y
Pippin
  • Birmingham
Re: Heating vents
« Reply #6 on: 11 December 2008, 17:19:08 »
Cheers Markey..... :y
Trade Card Holder
SP_3.2
  • Leicester
Re: Heating vents
« Reply #7 on: 11 December 2008, 17:25:34 »
Thanks ,good then ...mine is the same as yours chris.May check on the update and give the reset a try later. :y
Re: Heating vents
« Reply #8 on: 11 December 2008, 23:43:55 »
Resets on the 3.2 must be done ignition ON, engine not running .. might be the same for all facelifts but I don't know .. my old V reg would reset anytime ..
Re: Heating vents
« Reply #9 on: 12 December 2008, 00:04:36 »
Yep, nothing to worry about. It seems to be by design that heating occurs through the side vents. Perhaps to direct more hot air to the perimeter of the car where the maximum heat loss occurs - or to keep the windows clear. Either way both Chris' and my car do it, and both have been checked thoroughly.
SP_3.2
  • Leicester
Re: Heating vents
« Reply #10 on: 12 December 2008, 00:05:00 »
Thanks Entwood will do
Page created in 0.029 seconds with 20 queries.
