Author Topic: Knocking noise  (Read 4685 times)
Jay w
  • Plymouth/Poole
  • omega gone
Re: Knocking noise
« Reply #15 on: 03 December 2008, 19:02:06 »
Two more quick questions also  ::)
Can anyone suggest a decent place to get a new drivers track rod end from as prices and quality vary so much on ebay
Also when braking on ice today and abs kicked in it was very loud in shuddered the whole car and steering and didnt sound too clever.
To be honest this is the first time I have heard the abs since buying the car 12 months ago  :-/
yep sounds perfectly normal....
when the ABS kicks in and one of the wheels locks it feels like the whole front suspension has detached itself, very odd feeling
bighed
  • Shropshire
Re: Knocking noise
« Reply #16 on: 03 December 2008, 19:51:58 »
Thats ok then. Thanks for advice guys.
Martin_1962
Re: Knocking noise
« Reply #17 on: 03 December 2008, 22:10:50 »
COuld be a lifter, could be exhaust manifold
Grumpy
  • Manchester
Re: Knocking noise
« Reply #18 on: 03 December 2008, 22:45:32 »
http://www.vauxhall-car-parts.co.uk/acatalog/Omega-Steering.html
That's where I bought mine from a couple of months back. Seems ok
to me. Received it by return post, nicely boxed up and protected
inside the box with plastic wrap.
Fitted perfectly. All steering play nicely eliminated, sailed through MOT.
bighed
  • Shropshire
Re: Knocking noise
« Reply #19 on: 04 December 2008, 00:09:29 »
Its not exhaust manifold as already got that noise (drivers side) with a new vx manifold sat downstairs. Just got to find someone willing to fit it for a decent price. :-/ :y
bighed
  • Shropshire
Re: Knocking noise
« Reply #20 on: 04 December 2008, 00:10:20 »
thanks will give them a try  :y
Re: Knocking noise
« Reply #21 on: 04 December 2008, 09:27:07 »
Thats not strictly true.
« Last Edit: 04 December 2008, 10:03:43 by Elite_Pete »
bighed
  • Shropshire
Re: Knocking noise
« Reply #22 on: 04 December 2008, 18:19:39 »
Im all ears  :-/
bighed
  • Shropshire
Re: Knocking noise
« Reply #23 on: 05 December 2008, 18:37:46 »
PM replied to.
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Knocking noise
« Reply #24 on: 05 December 2008, 20:11:58 »
I needed a track rod end for MOT too, cost £29 at local motor factors. That was for the whole rod - initially I just got the outer arm, but couldn't detach the old one from the joining tube, so replaced the whole lot.
Very easy to do - once you have a ball joint tool!!!  ;D
craig
  • north wales/connah's quay
Re: Knocking noise
« Reply #25 on: 05 December 2008, 22:30:30 »
Did an oil change on sunday. Started car this morning and left running to defrost windscreen and went back inside.
When I came back out I could hear a light knocking noise coming from bottom of engine
This noise "goes away" after about 2500 rpm
Any ideas  :-/
Did you use engine flush at all??? when doing your oil change??
bighed
  • Shropshire
Re: Knocking noise
« Reply #26 on: 12 December 2008, 14:31:38 »
Hi, late reply. No didnt use engine flush  :y
So do you have to fit a FULL track rod arm or con the first piece be refitted on its own?
« Last Edit: 12 December 2008, 14:35:22 by bighed »
