Author Topic: Far from home - Oil levels  (Read 4579 times)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: Far from home - Oil levels
« Reply #15 on: 18 December 2008, 10:42:42 »
Whatever, top-up as necessary to the higher mark on the dipstick.
If there's no evidence of leak(s), you should be fine fella.
« Reply #16 on: 18 December 2008, 18:40:31 »
Mine comes up occasionally, but Oil Lack is the warning message.
If it is over minimum you are OK.
At high revs the oil is splashed everywhere - level is unreliable.
Measure after it has sat for a while
Varies with MID Martin Imber
« Reply #17 on: 18 December 2008, 18:41:10 »
As has been suggested, if around half on dippy, you do occasionally get the warning...
Martin_1962
« Reply #18 on: 18 December 2008, 20:20:14 »
Seen both - ie during oil changes to check messages
« Reply #19 on: 18 December 2008, 20:22:08 »
Not on the same MID you haven't ;)
Albatross
  • Bedford
  • An LSD & an S2000!
« Reply #20 on: 18 December 2008, 20:43:00 »
Thanks for all the advice.
I checked the dipstick this morning (I was a bit of a dipstick for not thinking of this myself) and it was just above the minimum.
I drove to the local stealers right after my meeting (they gave me TC discount too) and bought a litre; topped up and drove home fine.
Thanks again
Nathan
