Author Topic: Car phone  (Read 4165 times)
Re: Car phone
« Reply #15 on: 30 December 2008, 19:20:25 »
Also his MV6 has no cruise control  :-?
Would this just be the case of getting stalk fitted or is there more involved???
My car had no cruise control fitted when bought. Found one on EBAY fitted it (took about 5 mins rhen took it to a auxhall specialist to Tech 2 it and no problems since ;).Easy job :y
Yours is a 2.6 drive-by-wire and throttle / cruise is controlled by ECU, prefacelift will mean its a 3.0, and has a standard cable driven throttle body.
More required  ;)
Thanks just realised :-[
No problemo its easy to get confused on all the different engine combination.
In Short..
Full cruise kit needed on - 2.0 / 2.5 V6 / 3.0 V6
Just stalk needed on 2.2 / 2.5 TD / 2.6 V6 / 3.2 V6
Christian
  • Shropshire
Re: Car phone
« Reply #16 on: 30 December 2008, 21:49:57 »
So is it a no for a simple swap of the stalk then? yea my 3.0 has no flyby.
Nope i dont doo Sheep!
bighed
  • Shropshire
Re: Car phone
« Reply #17 on: 30 December 2008, 22:17:01 »
Gutted mate as cruise is the dogs on the motorways. Will have to look into how to change it n we will give it a crack!  :y
Re: Car phone
« Reply #18 on: 30 December 2008, 22:22:44 »
Still piss easy to do, just needs more bits:
Actuator
Cable
Brake switch
Clutch swith if manual
Stalk
Christian
  • Shropshire
Re: Car phone
« Reply #19 on: 30 December 2008, 22:25:26 »
Its an Auto, is there an FAQ on this guys?
Christian
  • Shropshire
Re: Car phone
« Reply #20 on: 30 December 2008, 22:26:22 »
Yea too right, when you free for us to have a crack at unblocking drain hole mate?
Re: Car phone
« Reply #21 on: 30 December 2008, 22:33:28 »
Not sure - check maint guides section.  But its easy anyway, though some MV6s have extra coolant pumps which need moving slightly
Christian
  • Shropshire
Re: Car phone
« Reply #22 on: 30 December 2008, 22:35:05 »
Ok will look into this when belt and drain holes are sorted, thanks for the help though, will get looking into this right away!
SteveMJ
  • Hertfordshire
Re: Car phone
« Reply #23 on: 01 January 2009, 22:29:16 »
only problem with it is the Drivers seat height adjuster dont work but it does on the passenger side, surly these would be fused together but they arnt because the other works, any tips guys?  :)
Mine seems similar (I'm awaiting a seat controller) if I disconnect the seat - large mutliway cable and then reconnect, the seat opeates fine for ~10 mins.
Is your's the same?
S
Steve
