Author Topic: Slight engine vibration at idle?  (Read 840 times)
trinity0_10
  • Norfolk
« on: 13 January 2009, 08:21:43 »
I have just returned from 5 weeks abroad, [ had a Holden Commadore Omega SV6 as a hire car,   :D :y , why haven't we got these cars here?]
Back to the question, running ours again it has a slight & annoying vibration at idle, it's the same on gas & petrol so I am thinking it's either a valve sticking or electrical.
Does a misfire cause the V6 to lump? is it pronounced? Also has anybody experienced a sticking valve?
It  still accelerates ok but fuel economy is down so something is amiss. I was looking for ideas before I jump in, probably first will be spark plugs & work back. Is there an additive if it's a sticking valve which works? heads off is a last resort at present. It's too bloody cold. ;D
« Last Edit: 13 January 2009, 08:22:32 by trinity0_10 »
Mike
Omega Elite 1999 2.5 saloon LPG
Vectra SRi 1998 2.0 Estate LPG
Re: Slight engine vibration at idle?
« Reply #1 on: 13 January 2009, 08:29:24 »
NEVER seen a stciking valev so that is very unlikely.....
Start with the ignition system checking for oil in the plug wells and examine the state of the leads.
trinity0_10
  • Norfolk
« Reply #2 on: 13 January 2009, 08:34:31 »
Hi, Thanks, forgot to say I had the leads off the plugs & sprayed WD40 just in case of damp. No oil in plug wells apart from middle drivers side. there is a little about 1 mm deep. Would a misfire cause the engine  to lump. I could try pulling all leads in turn to see if theres a difference? & look in the dark to check on tracking.
Mike
Page created in 0.022 seconds with 20 queries.
