Author Topic: Cam Belt Change  (Read 4265 times)
ScottieMV6
  • Swinton, Manchester
Re: Cam Belt Change
« Reply #15 on: 12 January 2009, 15:24:57 »
I only moved it a fraction. The belt seems to be still lined up with all the markings so don't know if it has slipped or not.
I'd rather be scared to death than bored to death!!
ians
  • Reading
Re: Cam Belt Change
« Reply #16 on: 12 January 2009, 15:45:37 »
Probably ok then. It won't move 1-2 until it goes tight around the top idler.  Just go steady and watch what's happening.
ScottieMV6
Re: Cam Belt Change
« Reply #17 on: 12 January 2009, 15:54:52 »
But then won't the timing be out?
Sorry first time doing a cam belt and I really can't afford to mess my engine up!!
ians
  • Reading
Re: Cam Belt Change
« Reply #18 on: 12 January 2009, 16:04:07 »
only by the 1/2 tooth per Mark, which you can then adjust out with the idler after you have rotated it.
ScottieMV6
Re: Cam Belt Change
« Reply #19 on: 13 January 2009, 12:21:07 »
Thanks for the help and advice. Loo-Knee and Elite Pete called earlier and sorted it out. :y
ians
  • Reading
Re: Cam Belt Change
« Reply #20 on: 13 January 2009, 13:01:08 »
Good to hear :y
What was the problem btw?  Could be useful for people reading this in future.
Cheers
Ian
ScottieMV6
Re: Cam Belt Change
« Reply #21 on: 13 January 2009, 13:21:26 »
Think I had fitted the belt a bit wrong and then it had slipped.
The guys had to start again from scratch.
Just glad it is sorted!! :y
