Author Topic: ignition on syl 2 and 3 only  (Read 2326 times)
Abiton
Re: ignition on syl 2 and 3 only
« Reply #15 on: 13 January 2009, 22:30:09 »
You've tried new plugs, right?
If not, could be tracking down the outside of plugs 1 & 4.
cnc-dude
« Reply #16 on: 13 January 2009, 22:51:21 »
The spark plugs are new.
There are three wires to the dis module. I believe one is signal for syl 1&4, one for 2&3 and the last one is ground.
I think I'm missing a signal from the ecu. I've measured the signal from the ecu when the engine is running (on 2&3), but I was not able to recognise any problems with a voltmeter. must probably have an oscilloscope.
Is the crankshaft and camshaft sensors the only input sensors that controls the ecu's ignition output?
« Last Edit: 13 January 2009, 23:05:12 by oms »
Abiton
« Reply #17 on: 13 January 2009, 23:28:45 »
Try tracing the two signal wires as they go along the cable tray that runs along the length of the engine.
We had a fault on ours that eventually turned out to be a wire-to wire short in this area.  Chafe between the CTS signal wire and injector wiring caused wire-to-wire short, and the CTS to die.  It's just possible you have the same thing going on but with a DISpack wire?
Worth a quick look maybe.  :)
