Author Topic: TD breather hoses?  (Read 1601 times)
Arrolman
  • Renfrew,Scotland
TD breather hoses?
« on: 21 January 2009, 19:24:22 »
Hi,
My omega is idling at just under 100rpm when I switch on in the morning, was just over 500rpm last week. Blocked breather hoses? Anyone like to point out where to check? Diagram maybe? :-/
Cheers,
Iain
Looking to win the lottery..........
Re: TD breather hoses?
« Reply #1 on: 21 January 2009, 19:25:54 »
Hi,
Cheers,
Iain
Idle increases as it warms up? Suspect CTS?
(Note: being a BMW engine, most failing or failed sensors do NOT bring on EML)
Arrolman
  • Renfrew,Scotland
« Reply #2 on: 21 January 2009, 19:28:19 »
Hi,
CTS? Idle doesn't increase, soon as throttle is moved it dips back to 500rpm
Iain
« Last Edit: 21 January 2009, 19:28:55 by Arrolman »
« Reply #3 on: 21 January 2009, 19:29:43 »
Coolant temp sensor.  2 CTS on that beemer unit, both in head. One (the single wire one) is used for dash, other (2 wire) used by ECU
« Reply #4 on: 21 January 2009, 19:30:23 »
If yours is paperclippable (about 50% of TDs are), iirc, cts is a 15
Arrolman
  • Renfrew,Scotland
« Reply #5 on: 21 January 2009, 19:32:15 »
Hi,
The stat is gone on it, nothing to do with that would it? Problem to repalce? Any need?
Iain
« Reply #6 on: 21 January 2009, 19:33:33 »
Hi,
Iain
Stat is easy on TD, though unrelated to your idle
Omegatoy
  • UK
« Reply #7 on: 21 January 2009, 19:34:32 »
if stat is stuck open cts will never get to correct temp!!! :y
Arrolman
  • Renfrew,Scotland
« Reply #8 on: 21 January 2009, 19:39:06 »
Hi,
Might be the problem then, going to get done this weekend, after i've managed to get the fan off ::), and the rear discs and shocks done, and the steering idler ;D
Cheers,
Iain
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #9 on: 21 January 2009, 22:09:33 »
Don't forget - viscous fan is left-hand thread.
A sharp jolt usually starts it undoing.
Page created in 0.029 seconds with 20 queries.
