Author Topic: Self Leveling Shocks or Standard?  (Read 4655 times)
Re: Self Leveling Shocks or Standard?
« Reply #15 on: 15 August 2008, 17:09:58 »
When your compressor's weren't working, what was the feel of the rear suspension? Mine on the Elite seems okay but a bit bumpy & rock hard when going over speed bumps. I'm just not sure that it should be like that.
Is this still with the original self levelling dampers? If so .... that'll be the reason it feels hard at the back, your dampers should be lifting the car up via the compressor. If the compressor is fubar'd I might consider oridnary dampers ..  :-/
Darkus Lordus
  • Mid Bedfordshire
« Reply #16 on: 09 November 2008, 20:24:33 »
Compressor seems fine. Initial problem was a leaking pipe going from the 'T' piece up to the passenger rear shocker. Found when I replaced a blown fuse & the compressor fired back into life & traced hissing sound. Now replaced both sides.
Still hard though....  :(
Darkus Lordus
  • Mid Bedfordshire
« Reply #17 on: 23 January 2009, 17:37:37 »
All Sorted now. Changed the shockers.
« Reply #18 on: 23 January 2009, 17:49:22 »
Congrats   :y :y :y Nice to hear its fixed  :)
As a minor aside .. your avatar is spilling over onto your text .... should not be bigger than 110 x 110 ... yours is 160 x 106 .. :)
« Last Edit: 23 January 2009, 17:49:41 by entwood »
Darkus Lordus
  • Mid Bedfordshire
« Reply #19 on: 25 January 2009, 20:30:54 »
Any better? There's no difference on my pc though.  :-/
« Reply #20 on: 25 January 2009, 21:15:50 »
still too wide.  It effects those gayboy users insisting on running firefox
« Reply #21 on: 25 January 2009, 21:42:37 »
Love you :-* :-* :-* ::) ::) ::) :D :D :D
Glynn
  • wirral
  • 3 LTR ELITE
« Reply #22 on: 25 January 2009, 21:50:55 »
thats a "firefoxist " comment if ever i heard one   :-/
firefox rocks !!    :y
[img name=signat_img_resize]http://i24.photobucket.com/albums/c18/glynn969/P8130334-1.jpg[/IMG]
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #23 on: 25 January 2009, 21:57:30 »
im using firefox atm and i wont be using it again!
only reason im using it is because my IE is setup for my proxy server and im using a 3g datacard which doesnt need the proxy
firefox loads pages up the wrong way!
Page created in 0.957 seconds with 16 queries.
