Author Topic: plugwhell full of coolant?!?!?!  (Read 3957 times)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: plugwhell full of coolant?!?!?!
« Reply #15 on: 31 January 2009, 23:50:44 »
Are you saying you did the cam cover gaskets, put it back together then it was running badly so you checked the plugs and found coolant in no1 plug well or did it run ok when you had changed the gaskets and put it back together?
Could simply be some coolant from the throttle body hose ran into the plug well as you were reassembling maybe.
TuBy's new whipping boy.
vrba
  • Croatia
« Reply #16 on: 31 January 2009, 23:53:02 »
no, cam cover replacer monts ago, this started happening now
« Reply #17 on: 01 February 2009, 00:15:13 »
you seemed fairly certain its coolent, if you taste it it will taste sweet, just to make sure. Is yellow coolent normal? Or is it just old?
vrba
  • Croatia
« Reply #18 on: 01 February 2009, 09:09:03 »
normal, i have put new after doing cam cower
