Author Topic: mistin up  (Read 3590 times)
philby
  • bedfordshire
Re: mistin up
« Reply #15 on: 30 January 2009, 20:20:22 »
hi  where about are the boot vents in the boot ??? :-/
Re: mistin up
« Reply #16 on: 31 January 2009, 00:35:47 »
You are correct :) :)
Just couldn`t resist ;D ;D ;D
Open boot. R/H side by lights, two circular locking wheels, undo and you`re there :y
philby
  • bedfordshire
Re: mistin up
« Reply #17 on: 01 February 2009, 20:45:27 »
hi , if  you  take the pollen filter out will it stop the mistin up ?? :-/
hotel21
  • The Kingdom of Fife
Re: mistin up
« Reply #18 on: 01 February 2009, 22:06:48 »
Only if its soaking wet....
Replace with a dry one, saves loads of flys (and pollen, if that bothers you) entering the passenger compartment....
Kieran
  • Dorset
Re: mistin up
« Reply #19 on: 01 February 2009, 22:20:08 »
If it is an estate it may be wise to open the rear curtain to allow the air to circulate :y
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: mistin up
« Reply #20 on: 01 February 2009, 22:24:44 »
I seem to remember reading that if you remove the pollen filter on a F/L (the charcoal filter type) the auto recirc control will switch to recirculating mode as it detects pollution in the incoming air.
TuBy's new whipping boy.
